Author Topic: leaking valve cover  (Read 4734 times)
April 13, 2008, 10:35:13 am
bigJ
  • 25
leaking valve cover
« on: April 13, 2008, 10:35:13 am »
I purchased an aftermarket head two years ago from a vendor who had found a batch in a wharehouse in Germany. I finally got around to installing it after doing some port and polishing. Once installed I could not get the valve cover to stop leaking. It turns out that the valve cover gasket sealing surface is too wide allowing the cover to sit on top.
http://www2.snapfish.com/slideshow/AlbumID=45461199/PictureID=4783954770/a=55513749_55513749/t_=555137499675/a=55513749_55513749/t_=55513749[/url]
Reply #1April 13, 2008, 03:23:13 pm
leaking valve cover
« Reply #1 on: April 13, 2008, 03:23:13 pm »
try switching to a cork gasket
Reply #2April 13, 2008, 06:55:31 pm
subsonic
  • 1836
leaking valve cover
« Reply #2 on: April 13, 2008, 06:55:31 pm »
Was this from a vendor in CA, who also sells on ebay?  Who is the maker of the head?
Reply #3April 13, 2008, 10:11:29 pm
bigJ
  • 25
leaking valve cover
« Reply #3 on: April 13, 2008, 10:11:29 pm »
Yes this was from california and also sells on e-bay. I could not find a single stamping or casting on who made this head. I do not blame the vendor as the fault was at the manufacturing level.
Reply #4April 14, 2008, 01:03:44 am
mufflerbearing
  • 61
leaking valve cover
« Reply #4 on: April 14, 2008, 01:03:44 am »
i dont see how a cork gasket will help as it sounds like the edge of the valve cover is hitting the head.
i would try machining down the edge of the head or switching out to a valve cover that does not have a lip coming down over the edge of the head. g60 valve cover for example.
-j
Reply #5April 14, 2008, 02:32:39 am
myke_w
  • 1099
leaking valve cover
« Reply #5 on: April 14, 2008, 02:32:39 am »
could you snap a pic of the head and post it?
Reply #6April 14, 2008, 05:49:19 am
subsonic
  • 1836
leaking valve cover
« Reply #6 on: April 14, 2008, 05:49:19 am »
Quote from: "bigJ"
Was it ecstyln or something close to that?
Reply #7April 14, 2008, 09:14:35 pm
bigJ
  • 25
leaking valve cover
« Reply #7 on: April 14, 2008, 09:14:35 pm »
I was able to use a Dermel and a hacksaw blade to remove the excess material while still on the vehicle and presto no more leaks. Before discovering the problem I was ready to retrofit a 1.6 valve cover which would require drilling and tapping for studs. Thank God it didn't come down to that!
