Author Topic: Factory air-water intercoolers?  (Read 11023 times)
Reply #15April 26, 2005, 06:09:09 pm
QuickTD
  • 1156
« Reply #15 on: April 26, 2005, 06:09:09 pm »
The new TDI uses a conventional air to air intercooler for charge cooling. It uses coolant to cool the fuel though. There is a seperate small coolant circuit that runs through an isolated tube in the top of the rad and cools a small amount of coolant to near ambient temp. This coolant is then used in a  coolant/fuel exchanger to cool the return fuel. The PD engine runs the fuel through the head quite close to the combustion chamber and puts a fair bit of heat into it, making the fuel cooler necessary.
  I seriously considered a air/water IC when I built my IC setup. The only problem that I noted with water cooled intercoolers is the dual heat exchange. The coolant/air rad cannot quite cool the cooling medium to ambient and the air/coolant rad that cools the charge cannot cool it to the temp of the coolant. Efficiency takes a double hit. Water cooled intercoolers are used to good advantage with an ice box for drag racing. They are also often used to solve serious packaging problems (blown mustangs come to mind) that simply cannot use an air/air IC. They also have an advantage in continuous high load conditions as they take longer to "soak".
Reply #16April 26, 2005, 07:57:47 pm
sethyboy85
  • 284
« Reply #16 on: April 26, 2005, 07:57:47 pm »
saab had a air/water unit
http://www.thedodgegarage.com/turbo_coolers.html
nice IC guide however check out some of the poeple's ride's, somebody was running a saab air/water unit, unless they changed it and updated their site.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #17April 27, 2005, 08:11:38 am
fspGTD
  • 1529
« Reply #17 on: April 27, 2005, 08:11:38 am »
Looks like there are a few different OEM units.  Thanks for the info guys...
PS - reason I asked:  The A1 NA Diesel intake manifold has a big rectangular opening that for a turbo-diesel application might be "cool" (literally  :P ) to weld an air-water core directly to:
It would make for a pretty tidy intercooler install, with the boost tubes not being much longer than they would be unintercooled.
Jake Russell
