Engine codes?
Topic: Engine codes? (Read 2478 times)
April 07, 2008, 07:29:08 pm
foxracer1
Authorized Vendor
Engine codes?
April 07, 2008, 07:29:08 pm »
I have a 1986 mf block and it has the hyd hump on the block. It also has an AMC head with the hump but the hump isn't drilled for oil. The block appears to have a plug in the port. My buddy also has a a mf but it is out of an 1985 and has no hump? Does any one know the science to reading engine codes?
The valve cover has the sticker that says it is hydraulic. The car has the valve lash sticker on the core support. The head has solid lifters.
Any ideas? I'd like to find a 1.9 head and run it but i would rather have a hyd block before i go to all the work.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
April 07, 2008, 07:35:44 pm
blkboostedtruck
Engine codes?
April 07, 2008, 07:35:44 pm »
theres one on samba
http://www.thesamba.com/vw/classifieds/detail.php?id=587078
sounds like you have a universal casting dependng on what the application that it was going to be used on?
go for the 1.9
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
April 07, 2008, 07:41:53 pm
foxracer1
Authorized Vendor
Engine codes?
April 07, 2008, 07:41:53 pm »
So are you saying its a hyd block but it was used for a solid? The cars date says 11/85. I figured it was an in between engine like an early hyd block but they used it for a solid lifter engine just becuse of the car they put it in. I'll check out that link thanks.
91 S10 305 TPI T56
April 07, 2008, 07:55:23 pm
blkboostedtruck
Engine codes?
April 07, 2008, 07:55:23 pm »
if it has the extra hump on the bock it's a hydro! and if it don't it's a mech.
thats all i know how to tell?
Duane
'66 variant 1500S
April 07, 2008, 08:20:12 pm
Engine codes?
April 07, 2008, 08:20:12 pm »
the amc head is aftermarket and may be a solid lifter head, my amc head is the same just has the extra drain hole blocked and its on top of a solid lifter block
April 07, 2008, 08:32:02 pm
foxracer1
Authorized Vendor
Engine codes?
April 07, 2008, 08:32:02 pm »
I would imagine if it has the hump then passages are drilled? It looks like the hole is just plugged. Thanks for all your help.
91 S10 305 TPI T56
Engine codes?
