Author Topic: starting an engine  (Read 3615 times)
April 03, 2008, 02:55:17 pm
mansvw
  • 85
starting an engine
« on: April 03, 2008, 02:55:17 pm »
Hi Guys,
 i was thinking about buying a 150Bhp PD Gti engine,,, but it doesn't come with clocks, key nor ecu....
can this engine be started in the same way a AAZ engines or do i require all the missing components above?
cheers
Mk3 Golf 1.9Td AAZ
Reply #1April 03, 2008, 03:27:14 pm
starting an engine
« Reply #1 on: April 03, 2008, 03:27:14 pm »
PD HAS to have the electronics.
Reply #2April 04, 2008, 03:12:10 am
mansvw
  • 85
starting an engine
« Reply #2 on: April 04, 2008, 03:12:10 am »
:cry:
does that mean ill need every thing? loom, ecu, keys and dials?
cheers
Mk3 Golf 1.9Td AAZ
Reply #3April 04, 2008, 05:57:17 am
starting an engine
« Reply #3 on: April 04, 2008, 05:57:17 am »
yep
Reply #4April 05, 2008, 05:55:05 pm
mansvw
  • 85
starting an engine
« Reply #4 on: April 05, 2008, 05:55:05 pm »
wotz the fun in that.......  :(
looks like i may have to stick with the AAZ after all...  :)
Mk3 Golf 1.9Td AAZ
Reply #5April 06, 2008, 04:20:00 am
starting an engine
« Reply #5 on: April 06, 2008, 04:20:00 am »
there's guy's running the lowest amount of electronics on the pd's with great success.  if you have access to what you need then i'd say go for it.  you will be much happier with it than an AAZ.  but if you can't find the extra bits to make it work then forget it.  they could be quite expensive depending on where you look.
