Author Topic: 1990 Jetta CL Timing Belt Procedure  (Read 2207 times)
April 02, 2008, 06:22:59 pm
Matteo
  • 47
« on: April 02, 2008, 06:22:59 pm »
Folks,
I just got my Timing Belt kit from Bleached Bora. (Thanks)
I have not received the Bentley manual I bought on ebay yet.
My question is:
- Can I just slip off the old belt, install the new tensioner, and slip on the new belt?
- Is it possible for the cam wheel to spin once the old belt is off?
- What weight/brand of oil should I use in the engine?
I am also changing the water pump.
- Do I need to use any type of sealer on the water pump gasket?
I'm an aircooled guy and not used to this liquid coolant stuff.
Any other tips/issues I should watch out for?
Thanks for your input,
Matt
Aircooled rules!
Biodiesel makes us better humans.
Make your own fuel and stick it to the man!
I never thought it was possible to Love a car.
Help me I'm sick!
Reply #1April 02, 2008, 06:55:26 pm
CoolAirVw
  • 175
Re: 1990 Jetta CL Timing Belt Procedure
« Reply #1 on: April 02, 2008, 06:55:26 pm »
Here's a link with instructions and copies of shop manual.
http://www.vwdieselparts.com/tbelt.htm
Quote from: "Matteo"
No.   You need to lock the cam with special tool (can be improvised with a flat peice of metal) and you need to lock the injection pump with a special tool (11 mm deepwell socket may work depending on brand)
The bolt in the center should be slightly loosened, and pull the pulley off the cam and then allow the pulley to spin on the cam while the cam is locked.  Dont forget to tighten the bolt later.
I like 5w-40 synthetic
Matter of preference.  I like silicone by itself with no gasket.
Me too!  Dont ya hate it when that green stuff leaks out and you get it on your skin, or worse yet you slip in it and fall on your @$$!
Check for leaks at IP seal, cam seal, front main, intermediate shaft.  Dont loosen the crank pulley bolt unless you have to.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #2April 02, 2008, 09:36:18 pm
« Reply #2 on: April 02, 2008, 09:36:18 pm »
also check the FAQ, vince has an excellent writeup on how to time the engine.
