umm $110 for pistons is a litle to much. How much oversize are they?mine were .020" over, so it sthe next size after stock.i think max is .040" over, cnat realy bore anymore then that, form what i've been told.also valves are usually pretty good in vw's, its the guides that wear, u probably wont need them, only reason i changed my exhaust valves is because they were hitting the pistons.Yeah they are CAN $. VM Autohaus is in burnaby, i think they can carry out parts locally. your in abbotsford arent u?
I just called VM autohaus and they qutoed me 108 for each piston, 020 overbore. They were gotze brand pistons I can get the original kolbenschidt for considerably cheaper... hmmm do you have an acount with them or something? Mark, we need tog et your engine out and I'll rip it apart and take it to a mchien shop to make sure the block can still be salvaged.
i cant remember wat kind of pistons i got, but i do get a discount there. Tell them that Sabi referred you and to see if they can match $80 the price i payed, make sure you talk to Chris at VM. He's the guy i deal with. VM should know wat kinda pistons i used.Good Luck, did you get similar prices at Dun-Rite?
Mark, kudos on pressing forward despite recent engine troubles.That is a nice looking cooler... it looks like it will flow well, with little pressure drop. I hope the install goes smoothly into the nose of the A3.Would love to see some pics and hear the details of how the o-ringing is performed!
