Author Topic: Oil temperatures... what is normal?  (Read 5423 times)
March 30, 2008, 01:56:29 pm
DonGTI
  • 172
« on: March 30, 2008, 01:56:29 pm »
Hi all
I finally completed my conversion to AAZ a week ago and amongst the things I added (list to come soom) is an oil to air oil cooler.  I removed the stock oil to water cooler and mounted a thermostat controlled sandwich plate which opens at 80 degerees Celcius.
Advantages over stock oil to water cooler are that oil gets to 85-90 degrees much faster, as well as noticing that the cooling system itself is running much cooler... possibly due to having a decreased load to cool the oil as well as engine block.
During hard driving, the highest I managed to get the oil is 118 degrees Celcius, however, after 15 minutes of traffic following a lengthy drive, the temperature soars up to 134-140 degrees celcius.
I'm currently using Gulf Multigrade for high performance diesels 15w40 as a break in oil, and will soon switch to shell semi sinthetic turbo diesel oil 10w40, but i don;t think that oil temperature would vary much between them.
What is the best operating temperature for oil in an aaz?
Thanks
Daniel
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #1March 31, 2008, 02:28:39 pm
Rvo
  • 8
oil
« Reply #1 on: March 31, 2008, 02:28:39 pm »
Maybe you should switch to sinthetic oil, if i see your high oil temperatures. This because semi-sinthetic oil "decomposes" with temperatures higher than 110°C losing its lubricating properties. The words i heard from a wise old man :wink:
 Grts Ronald
Reply #2March 31, 2008, 09:28:00 pm
DonGTI
  • 172
« Reply #2 on: March 31, 2008, 09:28:00 pm »
Thanks RVO
What oil grade should i go for? I was thinking 10w40 but now they are telling me that since over here we're considered a moderate-hot climate (lowest temps we got this winter were 7 deg celcius and right now we're already at 29 deg celcius) i should go for at least 15w40 maybe 20w50...
BUT
