Author Topic: B100 and Injection pump compatibility  (Read 3193 times)
April 19, 2005, 06:48:27 pm
jackbombay
  • 599
« on: April 19, 2005, 06:48:27 pm »
I read here somewhere that the internal pump seals are best upgraded to viton if you plan on using B100. Right now I am dealing with fuel line connections in my car and if the pump can't/shouldn't have B100 then I will not go through the expense and hassle of replacing all the non-metal bits of fuel line with Viton. I would really like it to all be B100 safe though. And lastly are Viton pump seals readily avalible? I assume that there a few different seals in my 5 banger pump than a 4 abnger pump as well...
Reply #1April 20, 2005, 01:26:32 pm
veeman
  • 421
« Reply #1 on: April 20, 2005, 01:26:32 pm »
Speaking of viton lines... Are viton hoses of that diameter available through regular parts outlets or is that an industrial item?  Sources?
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #2April 20, 2005, 01:28:22 pm
jackbombay
  • 599
« Reply #2 on: April 20, 2005, 01:28:22 pm »
Quote from: "veeman"
http://www.mcmaster.com/ has viton is any size you could need, but it is spendy.
Reply #3April 20, 2005, 08:38:12 pm
jackbombay
  • 599
« Reply #3 on: April 20, 2005, 08:38:12 pm »
Is the urethane clear? That would make it even better.
Reply #4April 20, 2005, 11:45:23 pm
wbhgrace
  • 5
« Reply #4 on: April 20, 2005, 11:45:23 pm »
McMaster sells tubing called Chemfluor 367 that is clear and biodiesel compatible.  It looks really neat on the fuel filter-to-injection pump line.  I used 1/4 ID x 3/8 OD and it pressed on the stock hose barbs real tight and doesn't need hose clamps.  And it costs a lot.
-Will
'81 Rabbit 1.6NA
'85 Westfalia Camper gas:(
Reply #5April 21, 2005, 03:31:47 am
Rat407
  • 289
« Reply #5 on: April 21, 2005, 03:31:47 am »
I got the blue urethane line from the local cycle shop. Looks sweet.
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #6April 21, 2005, 10:48:51 am
veeman
  • 421
« Reply #6 on: April 21, 2005, 10:48:51 am »
I recently saw a veggie conversion on a caddy that used lines that looked like the plastic lines used on pop machines and hot tubs.  Seriously.  It was clear and looked like it had some sort of fiber weave reinforcements in it.
I believe it's here...
http://forums.vwvortex.com/zerothread?id=1911981
81 Caddy TD
83 VW GTI FSP
86 4ktq
