Author Topic: spia dell'olio motore fuso?  (Read 3518 times)
March 29, 2008, 06:28:12 am
sabatino
« on: March 29, 2008, 06:28:12 am »
ciao, ho un problema col mio motore 1.9 td 55kw senza intercooler, ogni tanto mi si accendeva la spia dell'olio mentr camminavo a qualsiasi velocita' oppure da fermo ,sono ancato dal meccanico e mi ha consigliato di sostituire i bicchieri idraulici e la pompa dell'olio,fatto questo e misurato la pressione dell'olio secondo lui è tutto a posto ma nonostante tutto si sente un leggero ticchettio alle punterie e ogni tanto si accende la spia dell'olio cosa puo' essere mi date un consiglio?
Reply #1March 29, 2008, 09:03:34 pm
subsonic
  • 1836
Re: spia dell'olio motore fuso?
« Reply #1 on: March 29, 2008, 09:03:34 pm »
Quote from: "sabatino"
" Hello, I have a problem with my engine 1.9 td 55kw without intercooler, I may occasionally lit LED walked mentr of any speed 'or stationary, are ancato by mechanical and advised me to replace the glasses and the hydraulic pump oil, which is measured and the pressure he thinks all is well but nonetheless feels a slight ticking to punterie and occasionally turn on the light of what may 'be given me some advice? "
Reply #2March 29, 2008, 09:12:37 pm
« Reply #2 on: March 29, 2008, 09:12:37 pm »
nice to see this site attracting worldwide visitors :)
weird problem... wonder if he means the oil light is blinking? i bet its faulty sensors, but who knows...
Reply #3March 29, 2008, 09:27:48 pm
subsonic
  • 1836
« Reply #3 on: March 29, 2008, 09:27:48 pm »
Lets ask and find out :wink:
Do you mean that you have a blinking oil pressure light?
Lei vuol dire che hai una luce lampeggiante pressione olio?
What type of car do you have? The year, model etc....
Che tipo di auto avete? L'anno, il modello ecc ...
