Author Topic: Single stage injectors for high-power TDI?  (Read 4283 times)
March 24, 2008, 09:07:02 am
« on: March 24, 2008, 09:07:02 am »
Anyone thought of this yet?  Just wondering how this might work.  If the dual-stage injectors are on a TDI mainly for economy and noise reduction, would there be an advantage on a single-stage injector?  I would think that a single stage injection period would allow more flexibility at higher RPM's, as the duration of one single injection event would be shorter than two, allowing potentially more timing and more RPM's.  Yay or Nay?
Reply #1March 26, 2008, 04:57:54 pm
snakemaster
  • 405
« Reply #1 on: March 26, 2008, 04:57:54 pm »
i can see where you are comming from , i am going to put a set of .216 nozzles on single-stage injectors next week for my M tdi , and thay will be easer to pop test due to only one stage . i will let you know how it goes
Reply #2March 27, 2008, 08:26:42 am
« Reply #2 on: March 27, 2008, 08:26:42 am »
So there is a single-stage injector body already that fits the TDI?  Interesting.  Will really be curious to see what happens!  Would setting up the timing be any different on a single-stage injector?
Interesting to see if it will be any louder with these as well.  ;)
Reply #3March 27, 2008, 08:52:49 am
« Reply #3 on: March 27, 2008, 08:52:49 am »
I don't see why you couldn't just modify the stock injector to be single stage.
Reply #4March 27, 2008, 11:17:29 am
snakemaster
  • 405
« Reply #4 on: March 27, 2008, 11:17:29 am »
i have a set of single-stage injectors from a perkins prima ,as fitted to a montego as std , and i will put the .216 nozzles on them, there is other SS injectors on other diesel engins but it is just tracking them down .
Reply #5May 02, 2008, 04:49:32 am
snakemaster
  • 405
« Reply #5 on: May 02, 2008, 04:49:32 am »
i have not put theas injectors in my car coz my clutch is slipping with the stock ones at the mo so it will be a month or to before i get round to fitting them after my new clutch 8)
Reply #6May 02, 2008, 06:15:24 am
« Reply #6 on: May 02, 2008, 06:15:24 am »
Quote from: "snakemaster"
I'll be waiting.  :D
