Author Topic: pre chambers not flush  (Read 3228 times)
March 17, 2008, 05:59:35 am
moTthediesel
  • 194
« on: March 17, 2008, 05:59:35 am »
So I'm working on the head of my mechanical lifter 1.6TD engine. Everything looks fine, no cracks that I can see and it checks out nice and flat. The exhaust valve guides were worn almost to tolerance (about .045") so I replaced all the guides.
What does bother me though is the pre chambers. While they are not cracked, they are no longer flush with the head. They are flush in the area where they bear on the engine block, but they are standing proud of the head about .010 in the area diagonally opposite that. I have searched here and have seen a good bit about cracked chambers, but I've seen no mention of this particular problem.    :?:
Has anyone here seen this before, and do you see it as a major problem? With no cracking apparent, it doesn't seem likely that cause any real threat to damage the engine, but it still causes some concern for me.
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1March 17, 2008, 07:15:04 am
« Reply #1 on: March 17, 2008, 07:15:04 am »
I'd worry about it getting worse as that's about 1/3 to 1/2 the distance to hitting the piston, at which point all hell brakes loose. Who knows, maybe that's what happened to mine. I have no clue as to the cause, but can speculate about the head getting hot.
Reply #2March 17, 2008, 07:47:23 am
moTthediesel
  • 194
« Reply #2 on: March 17, 2008, 07:47:23 am »
Quote from: "libbybapa"
I would peen them in place.  Having one fall out into the cylinder is not unheard of and causes a very bad day.
Andrew
Ugh, I sure don't like the sound of that  :shock:
I've never seen a VW pre cup out, how deep do they project into the head? The only ones I've changed were on my LandCruiser, and they went a full 3/4" or so inside, very secure --
moT
'00 Jetta TDI 5spd
Reply #3March 17, 2008, 08:28:07 am
moTthediesel
  • 194
« Reply #3 on: March 17, 2008, 08:28:07 am »
Looking at the head again, what I see is that the pre cups are clearly deformed. The section of the cup that is covered by the head (just less than half it's area) is perfectly flush, the part inside the combustion chamber has "bent" down. Makes me wonder if they are cracked on the top side where they can't be seen?
Perhaps I should drive one out with a drift down through the injector socket so that it can be examined?
moT
'00 Jetta TDI 5spd
Reply #4March 17, 2008, 12:25:56 pm
CoolAirVw
  • 175
« Reply #4 on: March 17, 2008, 12:25:56 pm »
Quote from: "moTthediesel"
Better do something.
see this thread
http://www.vwdieselparts.com/forum/viewtopic.php?t=7799&highlight=
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #5March 17, 2008, 02:22:13 pm
« Reply #5 on: March 17, 2008, 02:22:13 pm »
wow i didn't know that could happen, kind of scary
Reply #6March 17, 2008, 02:45:28 pm
rallydiesel
  • 1880
« Reply #6 on: March 17, 2008, 02:45:28 pm »
That's why a TDI conversion is so nice. No more pre-cups to worry about.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7March 17, 2008, 04:35:16 pm
moTthediesel
  • 194
« Reply #7 on: March 17, 2008, 04:35:16 pm »
Quote from: "CoolAirVw"
see this thread
Thanks for that thread, scary, but helpful  :shock:
What were the rest of the cups in your head like? Interesting to me that all 4 of mine are exactly the same.
Not sure what I should do though --
Drive my cups out, install new ones, then peen? Where do I get cups? I don't think I've seen any parts places list them, and won't driving them out and pushing new ones in just make them looser?
Try to press the cups back to flush and then peen? Not sure that is do-able. Are they made of stainless steel or what?
Just peen the cups as they are now?
I do like the smooth ball peens shown in the pictures, much less likely to act as heat and stress risers than a sharp pin punch would be I think.
moT
'00 Jetta TDI 5spd
Reply #8March 18, 2008, 07:31:30 am
CoolAirVw
  • 175
« Reply #8 on: March 18, 2008, 07:31:30 am »
I believe the pre-cups are inconel.
I would try tapping them back in and then peening.
Andrew
what he said.
75 Porsche 914
93 GMC Truck
Reply #9March 18, 2008, 03:43:56 pm
Patrick
  • 1034
« Reply #9 on: March 18, 2008, 03:43:56 pm »
1.9 cups are available, don't think 1.6 cups are. IF you go that route, I think there's machining involved. I CAN tell you that if the cup breaks/comes loose, it WILL make a heck of a mess. Had one come out on a 1.6 and wreck a very good running engine. I've got 3 out of four good oversize pistons on the shelf........... THe fourth one looks like someone spent an hour or so hitting it with a chipping hammer. So does the head...............
