VWDiesel Blog
Facebook Group
VWD on Twitter
1.9 TD pistons in 1.6
Topic: 1.9 TD pistons in 1.6 (Read 2347 times)
March 16, 2008, 02:27:55 pm
Torchd
March 16, 2008, 02:27:55 pm »
Can i install 1.9TD pistons in a 1.6 NA or 1.6TD?
if yes.. what will i have to alter?
March 16, 2008, 03:09:35 pm
subsonic
March 16, 2008, 03:09:35 pm »
You will have to bore out the cylinders. I do not think that there would be enough structural integrity left to run safely.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
March 16, 2008, 04:15:06 pm
March 16, 2008, 04:15:06 pm »
Also neither rod would work. 1.9's are way too long, 1.6's are the wrong size and also may be the wrong length depending on if the pins are in different locations.
March 17, 2008, 02:14:21 am
Torchd
March 17, 2008, 02:14:21 am »
seen!!!
So lets say i get the cylinder bored to 1.9 piston specs....
would i be able to use the 1.9 wrist pins but 1.6 rods and get the bush bored to 26 mm.
and the distance between the wrist pin center to piston crown the same between 1.9 and 1.6??
