Author Topic: 2.8 tdi  (Read 2714 times)
March 15, 2008, 12:14:22 pm
svr6
  • 1
2.8 tdi
« on: March 15, 2008, 12:14:22 pm »
Hi can anyone help me,ihave a 02 2.8 tdi van,witch when you boot down in a high gear,under load the engine cuts right out,if your quick enough you can switch off the ignition ,then wind it over ,it starts right away,if you  feed on the power slowly it runs ok,or if you boot down in all the gears up through the gearbox it runs ok,it only happens when you boot down in a high gear,like if your coming up to a hill in 4th with hardly enough revs,then toe down,it will cut right out.!!!!
 Any help or advice would be great,thankyou for your time.
