Author Topic: Lightening and balancing the intermediate shaft.  (Read 26975 times)
Reply #45June 15, 2008, 06:39:16 pm
« Reply #45 on: June 15, 2008, 06:39:16 pm »
I looked through are there any pictures I missed of the finished balanced shaft? I saw the before ones, just wondering.
Reply #46June 15, 2008, 07:00:22 pm
DieselKraut
  • 54
« Reply #46 on: June 15, 2008, 07:00:22 pm »
[/img]
'80 Rabbit 1.5 IDI 126,00Mi Down but not out!
'83 Quantum 1.6 TD IDI
'90 Passat Gasser
Reply #47June 15, 2008, 07:15:35 pm
« Reply #47 on: June 15, 2008, 07:15:35 pm »
SWEET!  :shock:  :D
Reply #48June 16, 2008, 04:47:04 am
« Reply #48 on: June 16, 2008, 04:47:04 am »
very nice!!!
Reply #49July 05, 2008, 11:57:52 am
subsonic
  • 1836
« Reply #49 on: July 05, 2008, 11:57:52 am »
Here you go, before and after shots:  Worth doing if it's out.
Reply #50July 05, 2008, 12:00:59 pm
DieselKraut
  • 54
« Reply #50 on: July 05, 2008, 12:00:59 pm »
That looks sweet! I'm pulling my engine today and want to send off my IM shaft. Where did you have yours turned and balanced and how long did it take to get it back?
'90 Passat Gasser
Reply #51July 05, 2008, 12:16:40 pm
gigaz2
  • 626
« Reply #51 on: July 05, 2008, 12:16:40 pm »
I am definitely getting that done to my SB project  :shock:
Reply #52July 05, 2008, 02:05:01 pm
subsonic
  • 1836
« Reply #52 on: July 05, 2008, 02:05:01 pm »
Friend at a local machine shop did it for me.  Any decent shop should be able to do a good job.  Cost me one loaded cheese steak .
Reply #53July 05, 2008, 02:16:52 pm
gigaz2
  • 626
« Reply #53 on: July 05, 2008, 02:16:52 pm »
Quote from: "subsonic"
lol
locally I believe its going to be more expensive than that, a lot of machine shops closed, and the ones still open demand a lot for puny jobs like these :(
Reply #54August 29, 2008, 07:52:01 pm
riddleyo
  • 130
« Reply #54 on: August 29, 2008, 07:52:01 pm »
I just installed my lightened and balanced intermediate shaft.
Here are the pics:
Overall impressions: I don't notice any difference in power. The intermediate shaft spins at half the engine speed anyway. But my old intermediate shaft was broken, and I had to take my new one to the machine shop anyway, so I had this done.
I'm glad I did it though, one less part to worry about. And any freed up weight, no matter how small, is welcome on my car (it is an N/A, it needs all the help it can get)
1985 VW Golf Diesel 1.6L N/A
My Build Thread: http://www.vwdiesel.net/forum/index.php?topic=14607.0
Reply #55August 29, 2008, 10:10:24 pm
subsonic
  • 1836
« Reply #55 on: August 29, 2008, 10:10:24 pm »
Well, if you took off a pound or so of rotating mass, it is going to free up power.  It might be hard to tell, but trueing the shaft must help with vibrations.  In stock form it is ungodly out of balance.  Nice work.  I see you turned behind the gear as well.  Nice job.
Reply #56August 30, 2008, 03:22:40 am
Mark(The Miser)UK
  • 1557
« Reply #56 on: August 30, 2008, 03:22:40 am »
Neat job, but was it worthwhile? Shavings amount to a couple of oz's at most. Moment of inertia at 2000 rpm at max? But less than 1500 generally. 1cm from axis?
Remember the offending lobe was only the bit in excess of the ring of meat all way round.
As Sir Walter Raleigh would say "Small potatoes"
Nice lathe sample though :lol:
Mark-The-Miser-UK
Reply #57August 30, 2008, 05:35:09 am
subsonic
  • 1836
« Reply #57 on: August 30, 2008, 05:35:09 am »
Worthwhile is subjective.  The part needed to be replaced, and he all ready had it at the machine shop.  Turning the shft is a very simpy job.  Cost should have been low.  There is no question that the part is improved.  Balance has been improved and weight reduced, both good things.  Is it the same as a flywheel turned down to 10 pounds? No.
Does it help with engine performance / longevity?  Yes.
Would I pull the IM shaft just to turn it?  No way.  If I had it out during an engine rebuild, and had the opportunity to improve it at a low cost, would I?  I sure would.  Lots of small improvments add up to a better engine, cost goes up, but you still end up with a better product.
Reply #58August 30, 2008, 07:04:41 am
53 willys
« Reply #58 on: August 30, 2008, 07:04:41 am »
Man I got my IM shaft just sitting here...I think I may throw it in the lathe today and turn  mine down.
so did they take the tapper completely out of the shaft??
this should be a real easy job...I will weight mine before and after too.
Reply #59August 30, 2008, 11:04:18 am
VW Smokr
  • 114
« Reply #59 on: August 30, 2008, 11:04:18 am »
Some more info:
"So do you take the taper out of the shaft?  What about the lobe that is on the shaft, near the gear end, that drives the vacume pump?  Do you take that off as well?"
Reply:
"I take the taper out of the intermediate shaft as well as the bump."
From doing a bit of reading, it appears that the IM shaft is pretty rough, and I suspect, not very balanced.
 :idea:  I am going to put forth the hypothesis that the IM shaft being out of balance is one of the leading causes of the dreaded IM shaft bearing failure / flaking.
I would further suggest that balancing the shaft will reduce or eliminate many of these failures.
:idea:
Interesting!!! Then how do you run the vacuum pump, once you've installed the new lightened/balanced/bumpless IM shaft?
J.R.
