Author Topic: Quick spring question  (Read 3147 times)
March 14, 2008, 04:30:47 am
The Mad Hatter
  • 85
« on: March 14, 2008, 04:30:47 am »
Well, while i'm waiting to get the car back from the shop i'm gathering up parts here at the house.  I'm planning on doing a rear disc swap from a mk2 gti i found at my local junkyard.  I figure while i'm doing that swap i can replace the springs.  But, as i search for parts online, there are different part numbers for different mk2 golfs?  I thought they all used basically the same springs?
I'm looking to lower the car maybe 1.5"- 1.8".  Do i need to mix and match springs, or will any mk2 lowering springs work?  Thanks in advance!
Reply #1March 14, 2008, 07:57:30 am
DCC
  • 184
« Reply #1 on: March 14, 2008, 07:57:30 am »
There are basically 2 types of OEM springs for mk2 golf:
191 511 115 A is the standard spring (used on all GL, CL, GTD and GTI models) .
191 511 115 E and 191 511 115 F are the references for the 16v and G60 models (2 and 4 doors).
So, yes, any mk2 lowering spring will do the job. :)
