Author Topic: 11 mm plunger in a 1.6TD  (Read 4542 times)
March 07, 2008, 09:15:08 pm
la_poire
« on: March 07, 2008, 09:15:08 pm »
can i put a 11 mm plunger in my 1.6 td with AAZ dual stages injectors , gtd nozzles, and peugeot camplate? with a 20 mm axles (peugeot)? it is not too big? with 20 psi boost, AAZ head, fmic thanks
Reply #1March 10, 2008, 09:10:39 am
Benjamin
  • 485
« Reply #1 on: March 10, 2008, 09:10:39 am »
any 11mm wich turns Right (like your vw) will fit your pump, i dont see why you wanna use another camplate, unless you are realy knowing what you are doing, but than you shouldnt ask the question
Greetz, Benjamin
Must make +250hp
Reply #2March 11, 2008, 03:03:37 am
la_poire
« Reply #2 on: March 11, 2008, 03:03:37 am »
Quote from: "Benjamin"
Greetz, Benjamin
i can use fiat camplate in a IDI? if i can it's great, i fit the pump without modification  :D
Reply #3March 11, 2008, 03:54:26 am
la_poire
« Reply #3 on: March 11, 2008, 03:54:26 am »
Greetz, Benjamin
my 11 mm plunger came from tdi 2l fiat, fiat tdi camplate is ok for idi application?
Reply #4March 15, 2008, 02:11:38 am
la_poire
« Reply #4 on: March 15, 2008, 02:11:38 am »
Quote from: "libbybapa"
You don't want to use a TDI camplate on an IDI engine.
Andrew
it's the reason, i want to use peugeot camplate
Reply #5April 21, 2008, 06:26:44 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #5 on: April 21, 2008, 06:26:44 am »
I think you're talking about a Fiat Croma TDID pump. Yes it can be fit at our IDI's. The camplate is somewhere between our IDI and DI. Defenitely not suitable for our IDI's (replace with electronic DI camplate)
Reply #6April 21, 2008, 02:43:48 pm
mdonau
  • 53
« Reply #6 on: April 21, 2008, 02:43:48 pm »
i am running a xud12 (2,1L TD) pump with 10mm plunger..
my 11mm wont fit to the camplate... pump works great on my AAZ with 1Z timingbelt-wheel!
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #7April 21, 2008, 02:55:40 pm
dillenger1
  • 777
« Reply #7 on: April 21, 2008, 02:55:40 pm »
I used a LDA and 10mm plunger from a peugoet 505 td.While dissassembling the pump i measured some things and the camplate was the same as the one for the 1.6na
1.6td in toyota pickup
10mm head ,t3 intercooled.
