Author Topic: Do Injecters ever go bad+easiest way to remove  (Read 8610 times)
Reply #30July 24, 2011, 02:56:13 pm
guy plain
  • 121
Re: Do Injecters ever go bad+easiest way to remove
« Reply #30 on: July 24, 2011, 02:56:13 pm »
that there are potential gains available from lower injector pressures, rather than going higher...
 please explian....i know im interested...
Reply #31July 24, 2011, 04:53:59 pm
Mark(The Miser)UK
  • 1557
« Reply #31 on: July 24, 2011, 04:53:59 pm »
Higher break pressures were in part to help overcome nozzle faults, and part to allow for a quicker engine, ie faster burn of more fuel in conjunction with the additional air of the turbo.
In a swirl chamber, higher injection pressures, giving finer and finer sprays may develop penetration issues when fired across flow of compressed air.  Conversely, successful finer sprays can lead to 'better' combustion, ie quicker, but this can lead to higher peak pressures and temperatures and also increased Nox, increased heat loss through chamber.
Lower pressures may give better penetration and perhaps a longer burn due to the larger globules of fuel, giving a longer torque, lower max temps, less heat loss lower Nox, quieter engine. Less power absorbed in  injecting, and better fuel economy when cruising.
Mark-The-Miser-UK
Reply #32July 24, 2011, 05:21:36 pm
guy plain
  • 121
« Reply #32 on: July 24, 2011, 05:21:36 pm »
 so better in dayly use...long engine life....so would the higher pressure be better for high perfomance then? on and engine that wasnt ment to have a long life ...just hp?
Reply #33July 24, 2011, 05:50:08 pm
Mark(The Miser)UK
  • 1557
« Reply #33 on: July 24, 2011, 05:50:08 pm »
Probably yes  on average, however, engines are funny things and some take a lot of 'abuse' and don't wear at the same rate as others. Some are  born to be trouble.  I call it the Tom, Dick and Harry syndrome, but  if I use the film Christine to simplify; some engines are born to be bad. Clean burning of fuel and general engine care helps all engines though.
So many engines get killed off because of poor bodies. At least with these old diesels there is a chance of rebirth as a generator.
Mark-The-Miser-UK
Reply #34July 24, 2011, 06:53:50 pm
guy plain
  • 121
« Reply #34 on: July 24, 2011, 06:53:50 pm »
lol i grew up with detroit deisels....2 strokes....these 1.6 td,s are way different.....but i have 4 of them now...i do want to try one in a boat....i think the power/wieght is just about right for a small speed/cruiser
