Author Topic: Need IP front seal  (Read 5013 times)
March 04, 2008, 01:14:58 pm
TDDrew
  • 46
Need IP front seal
« on: March 04, 2008, 01:14:58 pm »
The 79 rabbit has been sitting for about a year. I went to start it and it wont lift any fuel. Pouring fuel into the pump inlet reveals that the pump front seal is puking fuel.
Where can I get a new front seal and are there any other seals I should consider replacing at this time.
Thanks,
Drew
79 Rabbit 1.6 Diesel 4 door
79 Rabbit 1.5 Diesel 2 door- with a/c, oooooo.
Reply #1March 04, 2008, 01:30:14 pm
rallydiesel
  • 1880
Need IP front seal
« Reply #1 on: March 04, 2008, 01:30:14 pm »
You could do them all. Are you sure the bushings are ok (it didn't leak before)?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 04, 2008, 05:43:33 pm
TDDrew
  • 46
Need IP front seal
« Reply #2 on: March 04, 2008, 05:43:33 pm »
Quote from: "rallydiesel"
It did not leak before, ran like a champ. My guess is that the seal just dried out, who knows maybe the fuel thats in there will swell the seal back up and it'll work fine.
I've never replaced the seals on the IP's before, nor have I been able to find them yet. Any recommendations?
Reply #3March 05, 2008, 08:11:54 am
dillenger1
  • 777
Need IP front seal
« Reply #3 on: March 05, 2008, 08:11:54 am »
dieselvw.com has them for like $5 I think
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4March 05, 2008, 08:42:46 am
Fisher
  • 148
Need IP front seal
« Reply #4 on: March 05, 2008, 08:42:46 am »
Southwest Diesel and Electric in Phoenix, AZ. is who I use.  Good service and fast shipping.
Reply #5March 05, 2008, 07:12:42 pm
TDDrew
  • 46
Need IP front seal
« Reply #5 on: March 05, 2008, 07:12:42 pm »
Thanks for the leads, I'll check them out.
Reply #6March 05, 2008, 07:43:25 pm
TDDrew
  • 46
Need IP front seal
« Reply #6 on: March 05, 2008, 07:43:25 pm »
Quote from: "Fisher"
Huh, I googled  this place and all I came up with was ford/dodge/chevy diesel parts here: http://www.swdiesel.com/
Can you post a link or do I need to call them for VW stuff?
Thanks,
Drew
Reply #7March 05, 2008, 11:11:08 pm
Fisher
  • 148
Need IP front seal
« Reply #7 on: March 05, 2008, 11:11:08 pm »
Call them.  I needed a TD Injector while on a road trip and they had it in stock.  NA11X.
I've called them and they've had the VW Pump Seals in stock and shipped very fast.
They will also rebuild Injectors and turn them around very fast if you request it.
Reply #8March 06, 2008, 08:26:05 am
myke_w
  • 1099
Need IP front seal
« Reply #8 on: March 06, 2008, 08:26:05 am »
you can get this seal at napa, it's part # 6611 Chicago Rawhide
Reply #9March 06, 2008, 01:29:39 pm
TDDrew
  • 46
Need IP front seal
« Reply #9 on: March 06, 2008, 01:29:39 pm »
Napa, I always forget about Napa. Thanks for the reminder.
Thanks agian for everyone's help.
Drew
