Fixmyvw.com
Author Topic: Air in fuel lines?  (Read 1625 times)
March 03, 2008, 07:31:41 pm
migs
  • 2
Air in fuel lines?
« on: March 03, 2008, 07:31:41 pm »
My 92 TD MK3 golf started to play up, when I leave the car off for around 6 hours or more I have to crank it for around 40seconds for it to start and sometimes even more.  After it starts if I switch it off right away and try to start it back it starts first time.
I dont think its the glow plugs but Im thinking it could be a leak in the lines?  My tank seems a bit wet but there is no visible diesel leak on the floor.
Also this problem dosent happen sometimes even if i leave the car off for a day which is wired.
Where should I be looking?
thanks
Reply #1March 03, 2008, 07:40:47 pm
rallydiesel
  • 1880
Air in fuel lines?
« Reply #1 on: March 03, 2008, 07:40:47 pm »
Check all your fuel line connections. You may also have a leaking main seal on your pump. Mine didn't leak with the timing belt on but the second I released tension on the belt it leaked like a sieve.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 19, 2008, 08:23:51 am
migs
  • 2
Air in fuel lines?
« Reply #2 on: March 19, 2008, 08:23:51 am »
where would be the usuall places for it to leak?  The tank conections?  Is there a lift pump inside the tank?
Fixmyvw.com
