Author Topic: mk2 tdi  (Read 3026 times)
February 29, 2008, 05:51:33 pm
dirtydiesel
  • 35
mk2 tdi
« on: February 29, 2008, 05:51:33 pm »
building a AHU TDI to put in a 1992 jetta any concerns with switching drive by wire
Reply #1February 29, 2008, 09:20:14 pm
hillfolk'r
  • 1532
mk2 tdi
« Reply #1 on: February 29, 2008, 09:20:14 pm »
trans?
swapping to cable shift?
shifter mounting...
clutch m/c install,i heard a corrado foot pedal cluster works,is that true yall??
i guess thats a little to start
Throttle cables ftw
Reply #2March 12, 2008, 07:48:07 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
mk2 tdi
« Reply #2 on: March 12, 2008, 07:48:07 pm »
I am working on an alh right now...
It all depends on what you are looking for.
1) full electronics as it would be in ahu engine
or
2) Mtdi setup.
Then you get to do this stuff:
The list above is a good start. I would also consider swapping in a mk3 k frame, axles, rear beam, front knuckles, front brakes.
you will have to do the following custom fabrications:
1)  shifter tower
2) go pedal (if going electronic)
3) clutch pedal (as stated above a passat one can also fit in)
4) intercooler
5) piping for boost, intake, intercooler
6) gauge cluster ( convert one or use the oem one)
7) ECU wiring.
the biggest things are the piping and the wiring. I have not quite got to the stages yet of getting the engine in yet. I am still working on seam welding and putting the cage in. That and some other one off modifications that will help the car a bit...
