Author Topic: Star wheel - how far?  (Read 2690 times)
February 27, 2008, 03:54:22 am
MontanaGTD
  • 230
    • http://www.dub-style.com
« on: February 27, 2008, 03:54:22 am »
Ok finally getting round to doing the star wheel mod - I know to turn it clockwise to adjust it, but i'm not sure how far I need to turn it??
The other thing is i've lengthened the pipe before which leads from the turbo to the wastegate actuator in preporation for putting a boost controller into - What is a "Safe" maximum boost limit for a 1.6 SB with intercooler to run? Its got a performance filter and a full exhaust system, i've adjusted the plunger pin and turned up the fuel, i've also blocked the BOV in preparation too. The boost at the moment tops out at just above 0.5BAR. And hardly any smoke!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1February 28, 2008, 02:54:02 pm
MontanaGTD
  • 230
« Reply #1 on: February 28, 2008, 02:54:02 pm »
Anyone?
MK3 Polo G40 - Sold
Reply #2February 28, 2008, 03:05:35 pm
Alleslowbuged
  • 270
« Reply #2 on: February 28, 2008, 03:05:35 pm »
Hi,
1,0 bar is realy no problem, with your intercooler  1,2 bar should be also reliable. Stock is 0,8 bar, so if you only have 0,5 bar, you are under stock boost level. If you wand to run with more than 1,0 bar, and get mor hp from the higher boost level, you also need a custom boost pin for you fuel pump, or live with very high amount of smoke, because otherwise you have to adjuste idle fuel amount to big, to get enough fuel at maxium boost.
best regards
Clemens
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #3February 28, 2008, 04:19:26 pm
« Reply #3 on: February 28, 2008, 04:19:26 pm »
I think it is a trial and error thing to adjust the starwheel. My pump doesn't have one, but as boost goes up, the pin allows max fuel sooner, so you adjust it up to give the spring more tension to correlate with the increased boost.
Reply #4February 29, 2008, 01:33:51 pm
Alleslowbuged
  • 270
« Reply #4 on: February 29, 2008, 01:33:51 pm »
Hi,
don't understand the star wheel question right before.
I think good deal is to adjuste the starwheel so, that you have approx 2-3 mm pre stress.
by clemens
BMW E28 524 TD
Reply #5February 29, 2008, 01:50:21 pm
MontanaGTD
  • 230
« Reply #5 on: February 29, 2008, 01:50:21 pm »
So just turn it a bit at a time and turn it back once it starts to smoke badly?
MK3 Polo G40 - Sold
Reply #6February 29, 2008, 01:50:54 pm
MontanaGTD
  • 230
« Reply #6 on: February 29, 2008, 01:50:54 pm »
Oh and swopped my boost gauge for a different one and i'm getting 0.75bar now!
MK3 Polo G40 - Sold
Reply #7February 29, 2008, 09:28:30 pm
hillfolk'r
  • 1532
« Reply #7 on: February 29, 2008, 09:28:30 pm »
i turned mine all the way down
then (since i got a ton of extra pump parts)i experimented with a propane torch to weaken the spring a little
seriously,you will notice a difference with 3/4 -1.5 turn,that ll be enough , but its not like you will blow it up if you turn it in too far,so try it for fun
for real fun some time,just remove the spring all together (and place it on top  instead  and do this) :twisted:  :twisted:  :twisted:  :twisted:  :twisted:
Throttle cables ftw
