Author Topic: ECOdiesel question  (Read 2503 times)
February 18, 2008, 06:23:03 pm
scrubb
  • 4
ECOdiesel question
« on: February 18, 2008, 06:23:03 pm »
Hi I will be installing a 1.6L ECOdiesel in a Suzuki sidekick. I will be mostly driving this on the freeway and was wondering what upgrades I can do for more power. Can I add a LDA? also with the tires I have and the sidekick gearing at 70MPH I will be turning about 3000 RPM's is this to much?
Reply #1February 18, 2008, 06:40:46 pm
eightyonerabbit
  • 51
Re: ECOdiesel question
« Reply #1 on: February 18, 2008, 06:40:46 pm »
Quote from: "scrubb"
you could get a TD I.P., get a longer geared transmission (to lower RPM's), get a free-flowing exhaust, turn in the fuel screw, etc... increasing fuel will yield higher EGT's tho, so i would reccommend getting a pyrometer...
Reply #2February 18, 2008, 06:40:51 pm
dieselsnowmobile
  • 103
ECOdiesel question
« Reply #2 on: February 18, 2008, 06:40:51 pm »
Correct, put a turbo pump on it with an LDA, bump you from 59 to 68 HP.  Could do a 3"straight pipe too.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #3February 18, 2008, 07:06:03 pm
ECOdiesel question
« Reply #3 on: February 18, 2008, 07:06:03 pm »
Sounds like a fun project, got any pics of what your building?
3000 rpms should be ok for freeway and yes as posted above you can add an LDA to your pump or get a true TD pump either way your set.
Reply #4February 18, 2008, 08:01:03 pm
ECOdiesel question
« Reply #4 on: February 18, 2008, 08:01:03 pm »
My rabbit does 3000rpm@70mph and I have one of the highest gear ratios you can put in a rabbit so they must be made for it.
Reply #5February 19, 2008, 05:04:14 am
scrubb
  • 4
ECOdiesel question
« Reply #5 on: February 19, 2008, 05:04:14 am »
here is a pic of the Sidekick
Is there a writup on how to add a LDA to a ECO pump? I would like to upgrade to a TD pump in the future but if I can upgrade the pump I have now that would be great.
Reply #6February 19, 2008, 08:34:27 am
ECOdiesel question
« Reply #6 on: February 19, 2008, 08:34:27 am »
gotta be a member to view it :(
Reply #7February 19, 2008, 10:12:47 am
scrubb
  • 4
ECOdiesel question
« Reply #7 on: February 19, 2008, 10:12:47 am »
I fixed the link
