Author Topic: my N/A diesel turbo build... 56k warning...  (Read 6917 times)
Reply #15February 21, 2008, 03:42:08 pm
eightyonerabbit
  • 51
« Reply #15 on: February 21, 2008, 03:42:08 pm »
its 8psi (which i believe is stock), i added a VERY LITTLE amount of fuel (turned the smoke screw in about 5 degrees...
Reply #16February 21, 2008, 05:55:26 pm
shegel
  • 312
« Reply #16 on: February 21, 2008, 05:55:26 pm »
what percent do you think the turbo added....see the thing is. if i could get an extra 10-20 hp i could get up the freeway hill next to my house without pissing anyone off.
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #17February 21, 2008, 06:03:40 pm
eightyonerabbit
  • 51
« Reply #17 on: February 21, 2008, 06:03:40 pm »
it probably added 5-8 hp with the stock NA fueling and 8psi of boost... with an IC, more boost, and more fuel, it would probably add between 10 and 20 hp... just depends on the car i guess..
Reply #18February 22, 2008, 10:48:44 am
fastvicar
  • 154
« Reply #18 on: February 22, 2008, 10:48:44 am »
My vote is 20hp on my Rabbi.  It changed it from dangerously slow to just dangerous.  I am running 12 psi though and fuel is turned up.  It makes nice noises to boot.
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #19February 22, 2008, 11:47:24 am
Baselyne
« Reply #19 on: February 22, 2008, 11:47:24 am »
Im also in the middle of both a headgasket and turboin my 1.5 stock rabbit
Wanna make a bet who's going to need rings first?
Nice build and   keep the text/pics coming man
This is good motivation
Reply #20February 22, 2008, 01:36:50 pm
fastvicar
  • 154
« Reply #20 on: February 22, 2008, 01:36:50 pm »
My head goes back on tonight.  I'll be keeping it at 12 psi at least until my ARP studs arrive.  Stock are going back in for now. (new stock that is)
Reply #21February 22, 2008, 06:32:15 pm
Baselyne
« Reply #21 on: February 22, 2008, 06:32:15 pm »
then arent you going to waist a head gasket then by compressing it and then having to change studs later...?
Can you do them one by one?
Reply #22February 23, 2008, 03:29:39 pm
eightyonerabbit
  • 51
« Reply #22 on: February 23, 2008, 03:29:39 pm »
found out where i can get a hold of a TD block... ill be rebuilding it and beefing it up a bit and possibly buying a TD IP... ill also be getting the ARP studs, a new head gasket, and possibly a new head (i think mine may be warped... ill have a machine shop check it out before it goes on the TD block)...
Reply #23February 25, 2008, 10:08:29 pm
eightyonerabbit
  • 51
« Reply #23 on: February 25, 2008, 10:08:29 pm »
anyone have a complete 1.6TD head?? if so, i may be looking to buy it in the next couple of weeks...
also lookin to put an LDA on my pump... how difficult is that to do??
Reply #24February 26, 2008, 06:40:14 pm
gratefuljoe
  • 41
NA turbo with Giles Pump?
« Reply #24 on: February 26, 2008, 06:40:14 pm »
I've got a 1.6 NA with a Giles pump.  I wonder if the increase in fueling and rev-range would boost EGT's too high if I did the same turbo install?
Thanks for the pics, this is great.
-gratefuljoe
1991 1.6 Golf NA G.P.
Reply #25February 26, 2008, 09:22:51 pm
eightyonerabbit
  • 51
Re: NA turbo with Giles Pump?
« Reply #25 on: February 26, 2008, 09:22:51 pm »
Quote from: "gratefuljoe"
-gratefuljoe
the boost should lower egt's if you do some sort of IC, and keep them either about the same or maybe a little lower without the IC... i never had a pyrometer before this install, so i dont have anything to compare it to...
Reply #26February 26, 2008, 11:43:33 pm
« Reply #26 on: February 26, 2008, 11:43:33 pm »
This tell's about it, I think the verdict is that it is possible, this tell's how. http://vwdiesel.net/phpBB/viewtopic.php?t=5031
Hope this helps! :)
Reply #27February 27, 2008, 10:51:21 am
fastvicar
  • 154
« Reply #27 on: February 27, 2008, 10:51:21 am »
Quote from: "Baselyne"
I asked my hot-rodding diesel-mechanic friend and he claims that there should be no ill-effects by doing them one-by-one.  TDI guys have been doing it for awhile now.
Reply #28March 01, 2008, 09:28:45 am
eightyonerabbit
  • 51
« Reply #28 on: March 01, 2008, 09:28:45 am »
i need to hurry up and get some sort of exhaust system on this ***.. the open downpipe is makin me high all the time haha..
