Author Topic: How much blowby it too much?  (Read 13834 times)
Reply #15February 21, 2008, 04:39:29 am
myke_w
  • 1099
« Reply #15 on: February 21, 2008, 04:39:29 am »
Quote from: "Vincent Waldon"
I used to think the "S" was for Spark ignition, and the "C" for Compression ignition, but no...... evidently S is for Service, and C is for Commercial.
Huh, well that's wild..
I'm guessing it's a moot point what it stands for since, it's a safe assumption that commercial vehicles would mostly be diesel anyway...
Thanks for that contribution Vincent, ya learn something new everyday ;)
Reply #16February 21, 2008, 07:47:03 pm
blkboostedtruck
  • 1535
« Reply #16 on: February 21, 2008, 07:47:03 pm »
ahhh yes! thanks guys! i'm all geeked out on oil science! i thought there was more to then just a brand and viscoisity? never realizied it?
that helped me more then you think! i truley had no clue!
now i know i can make my next engine rebuild last longer with the right oil instead of what ever is on sale nomatter what it is!
what made me think of this is recently? at work i leave my rabbit running all day. and had been using about 2quarts of cheap oil after 8to9 hours ideling at work! and when i would take off to go home she would smoke real bad for about a good block! so i went through the cheap oil real fast! then i bought some rotella! now my oil consum is down to 1/2 a quart in a 8to9 hour of ideling at work! and nearly no smoke when i take off and drive home!
so that what got me really thinking about the actual out of date knowledge i knew about oils!
well thanks again guys
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #17February 21, 2008, 09:55:50 pm
« Reply #17 on: February 21, 2008, 09:55:50 pm »
Quote from: "blkboostedtruck"
Duane... I hope that you realize that Al Gore and a carload of homeless polar bears will now show up at your door and punch you in the nose ???!!!  :lol:
Reply #18February 21, 2008, 11:04:53 pm
« Reply #18 on: February 21, 2008, 11:04:53 pm »
I'm curious, why do you leave it running Duane?
Reply #19February 22, 2008, 12:48:49 pm
« Reply #19 on: February 22, 2008, 12:48:49 pm »
hahaha, homeless polar bears. Ya ever hear that a few years ago a polar bear from the north slope hopped on an ice berg and floated down to southern Alaska, 'course he didn't know were he was goin' though. They like warmth once in a while too! Check this out.
http://www.snopes.com/politics/bush/house.asp
http://newsbusters.org/node/11073
http://pajamasmedia.com/2007/02/al_gores_house.php
Man, there is no way our smoke blowin' diesels can keep up to this guy!!
Reply #20February 23, 2008, 04:35:14 pm
blkboostedtruck
  • 1535
« Reply #20 on: February 23, 2008, 04:35:14 pm »
sorry guys i been working  a lot !
I work heavy construction and my warm break and lunch room is my rabbit!
so if Al Gore and a bunch of homeless polar bears find me they better pack a lunch because i'm not sharing mine after setting bridge girdiers all day with a 200 ton crane out in the cold weather!
when it's below 10degrees i leave it running!
today it was up to 32degrees and i shut it off!
Duane
'66 variant 1500S
