135 or 150bar injectors?
Topic: 135 or 150bar injectors? (Read 1951 times)
February 15, 2008, 07:06:10 pm
turbosuzi
February 15, 2008, 07:06:10 pm »
On the 2.6td w/na pump which injectors are best 135bar or 150bar?
February 15, 2008, 07:44:23 pm
blkboostedtruck
February 15, 2008, 07:44:23 pm »
id say run with the injectors that were originally with the pump 135bar?
unless you know your pump can push the extra pressure needed for the higher breaking pressure injectors? but thats my opinion?
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
February 15, 2008, 08:26:08 pm
February 15, 2008, 08:26:08 pm »
the pump should have no problem making those pressures... the time in which it does is what will be different... might take a few micro seconds to produce that extra bit of pressure. that may translate in a few hundredths of a mm of timing? :wink:
