Author Topic: Error code P1556  (Read 4788 times)
February 14, 2008, 04:35:02 pm
Bobt250
  • 7
Error code P1556
« on: February 14, 2008, 04:35:02 pm »
Low power and a code P1556. Says that the turbo pressure controller valve has deviated positive......or something like that, as best I can remember.
Anyone know what this means and what to do about it?
Thanks
Reply #1February 15, 2008, 05:53:43 am
  • 1739
Error code P1556
« Reply #1 on: February 15, 2008, 05:53:43 am »
basically the waste gate system is stuck or has failed. if you can get under the car, check at the actuator. the lever that it pulls might be seized.with  a small pair vise grips attached to the square lever you should be able to move it up and down about 2-3 cm or about an inch. if it's seized you can sometimes free it up by spraying some wd 40 while moving it. if it's bad it will take quite a while before it gets loose. if it does free up, apply some anti seize by brush [make sure you get it right into the mechanism] or with copper anti seize spray.
if it's free already then check the hose that runs to the actuater to the solinoid. check all the other hoses to the solinoid also. if that doesn't work either the solinoid isn't being triggered or has failed.
worse case scenerio is the the turbo itself has failed and you'll need to replace it.
if you do and whoever changes it doesn't need the core i'm sure me or someone else on this forum would buy it.
