Author Topic: 1.9 AAZ Head Gasket question  (Read 2034 times)
February 11, 2008, 09:05:08 pm
starrd
  • 128
« on: February 11, 2008, 09:05:08 pm »
Just measured my piston protusion on my 1.9 AAZ build and it is 0.026", which I know requires a 1 notch head gasket.  My question is, do people use other than the factory settings to lower compression slightly?  I am going to be running 18 PSI boost, K24 turbo, giles pump, intercooler and 2 1/2" downpipe.  I know this affects the squish, but I want to make sure I order the right one.  Any opinions or suggestions are welcome.  Thanks
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
