VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Upgrades (non engine related )
How to fix door handles on Mk2?
Topic: How to fix door handles on Mk2? (Read 4751 times)
February 08, 2008, 04:03:27 pm
914turboford
February 08, 2008, 04:03:27 pm »
Is there some sort of fix for the door handles on a Mk2? or Mk1, for that matter. Everyone seems to accept the fact that the doors are difficult to open from the outside. Can you bend the linkage or something?
Brian
February 08, 2008, 04:04:45 pm
rallydiesel
February 08, 2008, 04:04:45 pm »
Moving the striker pin a bit usually makes a big difference. Spray some WD40 into the lever to loosen it up as well.
1991 Jetta TD - sold
2001 Golf TDI - Son's
February 08, 2008, 05:32:21 pm
February 08, 2008, 05:32:21 pm »
i've broken one once from extreme cold (20 year old car)... it was so brittle :lol: needless to say i spray in some rust check every year or so... it makes the difference
February 11, 2008, 10:18:49 am
Zulfiqar
February 11, 2008, 10:18:49 am »
I put some heatshrink tubing on the finger that presses the lock mechanism tongue, I can now open it with one finger pull
and liberally lube up the handle crank mechanism with ATF
Diesel IS the future
February 11, 2008, 02:12:06 pm
February 11, 2008, 02:12:06 pm »
I've found that if the handle is sticking shut you can loosen the screw in the side of the door a bit and that usually helps
February 11, 2008, 02:45:30 pm
February 11, 2008, 02:45:30 pm »
Replace them with mk3 style handles and keep them lubed up as mentioned above.
February 11, 2008, 03:38:51 pm
914turboford
February 11, 2008, 03:38:51 pm »
Thank you for the advice.
Brian
February 12, 2008, 10:34:52 am
G60ING
Corrado TDI
February 12, 2008, 10:34:52 am »
Make certain you lube the locking/latching mechanism, the grit in latch causes the extra stress to be placed on the door handle mechanism.
General Information
