Author Topic: appropriate mechanical pumps?  (Read 3747 times)
February 06, 2008, 09:23:39 pm
Jeremy
  • 6
« on: February 06, 2008, 09:23:39 pm »
I was wondering if by chance there was some supreme being outhere that would be kind enough to post/point me in the direction of a list of bosch mechanical pumps for use on a TDI-M set up.  Something in the way of an application guide would be ideal.  Failing that does anyone know if the pump off of a peugeot 306 d turbo would be appropriate?
thanks
Reply #1February 09, 2008, 05:54:17 pm
dillenger1
  • 777
« Reply #1 on: February 09, 2008, 05:54:17 pm »
Im using the lda off a peugoet 505.The mounting holes are different then vws three hole triangle.the snout is the same.The boost pins location seemed to be pretty advanced on the curve for stock location.
thats the lda on my vw pump. :D
the original peugoet pump :D
boost pin
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2February 09, 2008, 09:30:54 pm
hillfolk'r
  • 1532
« Reply #2 on: February 09, 2008, 09:30:54 pm »
um,boost pin???
 :shock:  :shock:
set it stock
or wild
this may help
use these
my pump is from an 84 jetta turbodiesel,modified with a 12mm pump head from a cummins 4b pump
heres the current setup,mercedes turbo,and upside down 4-2 manifold,3 inch dp
she runs ok :wink:
Throttle cables ftw
