Author Topic: Golf MK1 with 1.6 TD (CY) --- Diesel race car project  (Read 39748 times)
Reply #30February 01, 2010, 03:06:31 pm
Alleslowbuged
  • 270
Re: My Golf MK1 with 1.6 TD (CY) swap to 1.9 TD (AAZ)
« Reply #30 on: February 01, 2010, 03:06:31 pm »
Dear all,
i get my ported and polish 1.6 mechanical head back, also the valve seats has been mashined to a slightly bigger diameter
I will use the LT28 intake manifold, modified to a dual plenum intake and also with ported chamber (same as head intake ports).
Here is a picture, with pipe direction to the wrong side (non driver side):
Here the new gaskets:
I have also take my 1.6mm MLS gasket to mark the additionally "steam holes", then
i have drilled 4mm holes.
Best Regards
Clemens
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #31February 03, 2010, 01:27:35 pm
  • 3468
    • McScrubbins Body Wash
« Reply #31 on: February 03, 2010, 01:27:35 pm »
Fantastic port job.
Reply #32February 03, 2010, 01:47:00 pm
rallydiesel
  • 1880
« Reply #32 on: February 03, 2010, 01:47:00 pm »
Nice build. What happened to the 1.9 plans?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #33February 03, 2010, 02:08:19 pm
Alleslowbuged
  • 270
Re: Golf MK1 with 1.6 TD (CY) --- Diesel race car project
« Reply #33 on: February 03, 2010, 02:08:19 pm »
Hello,
i have just the title of this thread, as also the car the change from my old mk1 street car
(which should get a 1.9td swap) to the yellow race mk1 with 1.6 td engine.
As compensation for the other mk1, i have bought a mk2 with aaz engine which is actual
broke down. Here is the link:  http://www.vwdiesel.net/forum/index.php?topic=24407.msg186924#msg186924
Best Regards
Alleslowbuged
BMW E28 524 TD
Reply #34December 30, 2011, 01:46:05 pm
Alleslowbuged
  • 270
« Reply #34 on: December 30, 2011, 01:46:05 pm »
Hi,
i did not have wrote here for long time and to be honest i did not have make big progress, but it is still an actual (waiting) project.
here is a picture, what happens if stupid person (the same who has made the hopefully good port job) don't listen and make what
he wants, after years of waiting. The pipe-part is cut out again, but the manifold is still waiting for new effort.
Next step was to make a stand-alone outer part of the shaft drives. The parts a needed to pre-stress the front wheel bearings,
otherwise the bearings will be scrap if the have to carry the full weigth of engine and chassi.
So after this was done, i could put the whole front axis together and put the car on its own wheels (first since it is mine):
Whith the 14" rims it is pretty tight with the brakes:
Next was the brakes itself, i have bought a set of "stahlfelx" (i don't know the english word) flexible brake hoses and
will install them inside the car:
The actual status is, that the two hoses to the rear brakes are in the cabin and i have drill two additional holes in the back domes
to bring them out to the brake again.
I will go ahead with special Ø256mm rear brake disks and stock (MKII) Ø38mm brake caliper. Here are some pics of the installed
disks and adapter together with the new rear shock damper:
As the 14" rims do not fit with the rear brake, i put the car on a set of 15" rims:
I have bought a new honed (first oversize) SB engine block with new pistons will go ahead with that.
To use my mechanical cylinderhead i still have to close the additional oil return hole. But more unlikely
is, that the guy i bought the engine from was a 100% specialist, who put all bearing covers together
in a box and used for each cylinder the one which was first to catch. After that he was wondering, why
the engine could not rotate, but he tried to rotate it, which results in some unpretty marks in the new pistons.
Anyhow, i have measured all parts, find their correct place and came to the conclusion that everything can
still be used.
Here is a scratch at the upper part of the pistons:
and to pistons with scratch at the lower part:
I have shown the pistons a proffesionell engine rebuild shop and they meaned that it is not that bad, so i have
regrinded the spots.
Today i have swapped the stock conn-rods to a set of china H-beam con-rods:
Best Regards
Alleslowbuged
Last step was today t
« Last Edit: December 30, 2011, 01:55:58 pm by Alleslowbuged »
BMW E28 524 TD
Reply #35December 30, 2011, 06:49:57 pm
410
  • 581
« Reply #35 on: December 30, 2011, 06:49:57 pm »
I love pictures. :)
Reply #36December 30, 2011, 07:45:49 pm
« Reply #36 on: December 30, 2011, 07:45:49 pm »
Wow, dude that is such a cool lookin' car!!!!
Any idea what the scratches in the piston are from?
Reply #37December 30, 2011, 09:30:08 pm
Powered by Spearco
  • 1203
« Reply #37 on: December 30, 2011, 09:30:08 pm »
Nice shift linkage. The same as I use on my 02J but with an 02A tower.
Nice little car.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #38December 31, 2011, 01:45:18 am
Mark(The Miser)UK
  • 1557
« Reply #38 on: December 31, 2011, 01:45:18 am »
Neither of those sets of marks look like they were created during engine operation. Down at the skirt looks like a bench clamping issue.
Top gouge is one way only and probably comes from someone slipping out of the ring groove whilst cleaning with a piece of ring...
No to-ing and fro-ing affirms this 8)
Mark-The-Miser-UK
Reply #39December 31, 2011, 03:44:23 am
Alleslowbuged
  • 270
« Reply #39 on: December 31, 2011, 03:44:23 am »
Hi,
@Mark
you properly right, the engine rebuilder says the same. Regarding the upper scratch he also means that as long as the ring is totally free to move,
this would be no issue, as dark black smoke will close the extra space from the scratch rather quick.
Greets
Alleslowbuged
P.S.
What means to-ing and fro-ing?
BMW E28 524 TD
Reply #40December 31, 2011, 08:55:27 am
Mark(The Miser)UK
  • 1557
« Reply #40 on: December 31, 2011, 08:55:27 am »
Hi,
@Mark
Greets
Alleslowbuged
P.S.
Chuckle brothers would say "to me, to you".
Perhaps backwards and forwards, or shuffling, 'working' it's way down, up and down, 'in and out'... ;D
Mark-The-Miser-UK
Reply #41January 01, 2012, 11:46:17 am
mtrans
  • 308
« Reply #41 on: January 01, 2012, 11:46:17 am »
ccc....puzzle again.
I`ll improve my English
Reply #42January 06, 2012, 09:27:40 am
baldone
« Reply #42 on: January 06, 2012, 09:27:40 am »
what kind an intake manifold have you used?
Reply #43March 04, 2012, 01:49:07 pm
Alleslowbuged
  • 270
« Reply #43 on: March 04, 2012, 01:49:07 pm »
Hi,
as short update, i could finish the rear brakes today:
left:
right:
So at least i have to fill it up (brake system) und deaerate it.
Best Regards
BMW E28 524 TD
Reply #44March 04, 2012, 05:22:00 pm
CrazyAndy
  • 739
« Reply #44 on: March 04, 2012, 05:22:00 pm »
Nice little car.
Yeah, I've seen that setup before.  You got it from Claus von Essen Chassis Works & Golf 1 Special Parts didn't you?
http://www.clausvonessen.de/pi38/pd648.html
Totally gonna get that setup myself.  What's the diff-mounted relay lever off of, or is that in the kit too?
Finally nice to see a working pic of it on a car, and the Corrado/Eurovan clutch actuator; this looks to be a seriosly good car.  8)
Thanks for the progress pictures!
