Author Topic: Golf MK1 with 1.6 TD (CY) --- Diesel race car project  (Read 40292 times)
Reply #15January 12, 2009, 03:56:50 pm
  • 3468
    • McScrubbins Body Wash
My Golf MK1 with 1.6 TD (CY) swap to 1.9 TD (AAZ)
« Reply #15 on: January 12, 2009, 03:56:50 pm »
First of all, it is very nice to see american guys to work with old german engineered Turbo Diesel (IDI) stuff, mainly in that crasy professional way i see here.
And Canadians! we may be few in numbers but we count too!  :P
Reply #16January 13, 2009, 12:00:11 pm
Alleslowbuged
  • 270
« Reply #16 on: January 13, 2009, 12:00:11 pm »
Hi,
sure also the candian and the scandinavian and all other amazing guys here you bild up crazy IDI engines.
Best Regards
Clemens
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #17January 14, 2009, 04:10:32 am
regcheeseman
  • 714
« Reply #17 on: January 14, 2009, 04:10:32 am »
Don't suppose you remember where or who the clutch was from?
Reply #18January 14, 2009, 03:23:59 pm
Alleslowbuged
  • 270
« Reply #18 on: January 14, 2009, 03:23:59 pm »
Hi,
i get my coupling from ebay.de, it was pretty new, but from a private who could not use it. But just before i found it on ebay, i was in conatct whith dss (diesel speed shop), here is the link, with a competitive price:
http://www.diesel-speed-shop.com/index_fichiers/Page1829.htm
I have got my mls custom head gaskets for my 1.6 TD (mechanical) from gasket-to-go today, here some picture:
http://s702.photobucket.com/albums/ww24/euro-styler/?action=view&current=P1010006.jpg
Best Regards
Clemens
BMW E28 524 TD
Reply #19February 01, 2009, 05:54:50 pm
Alleslowbuged
  • 270
« Reply #19 on: February 01, 2009, 05:54:50 pm »
Hi,
so my 500Nm clutch is installed and the 02a (ASD) tranny in bolted on.
http://s702.photobucket.com/albums/ww24/euro-styler/?action=view&current=1-6-td-mit-02a-Getriebe.jpg
greets from germany
BMW E28 524 TD
Reply #20April 26, 2009, 02:20:23 pm
Alleslowbuged
  • 270
« Reply #20 on: April 26, 2009, 02:20:23 pm »
Dear all,
i have had a week vacation, so i could make some proceed on my diesel race car.
The main time i have worked on the suspension and brake sytem.
On the front axis, i have get my adjustable (camber and caster) strut bearing and could assemble the complette axis incl. the brake. I have also installed PU bearing for the control arm.
I hat some issue to install the strut bearings on the suspension, but could fix that.
I have pull all parts to max. negative camber, thats why it looks so extrem.
Knowing, that this will bring no proceed, i wand to know how it looks with my rims. The rims are 14" and fit radial with the brake, but for axial fitting, i have to use 20mm plates (picture with 23mm plates).
On the rear axis, i have mashined wheel hubs from the stock brake drum, so that i could use every VA brake disk. Actual status is to manufacture a brake mounting adapter. I have also installe negative camber plates and a adapter plate, which bring the rear axis down, if the car is lowered.
Here is a link to all pics:
http://s702.photobucket.com/albums/ww24/euro-styler/?action=view&current=Hinterachse_16.jpg
Best Regards,
Alleslowbuged, who just bought a S2B Schwitzer turbo charger for his 1987, 524 TD E28 BMW.
BMW E28 524 TD
Reply #21April 26, 2009, 05:59:28 pm
OmnibusX
  • 39
    • http://www.youtube.com/user/OmnibusX
« Reply #21 on: April 26, 2009, 05:59:28 pm »
Very nice:D interesting reading keep up the good work
94 VW Golf GL MK3 1.9 TDK
85 Toyota Corolla 1.3
86 VW Golf CL MK2 1.8
89 Peugeot 205 GTI 1.6
84 Peugeot 205 GTI 1.6
Reply #22April 27, 2009, 03:34:53 pm
TurboJ
  • 661
« Reply #22 on: April 27, 2009, 03:34:53 pm »
Looking really good! Very nice project!!
Jetta II 1.6 TD 'Project 200'
Reply #23May 24, 2009, 02:24:37 pm
Alleslowbuged
  • 270
Re: My Golf MK1 with 1.6 TD (CY) swap to 1.9 TD (AAZ)
« Reply #23 on: May 24, 2009, 02:24:37 pm »
Dear all,
first thanks for your nice comments, it is good to hear, that my own *** is also interessting for other guys.
I good make some process on the weekend, my fia approved seat comes on friday i could nearly finish to install it.
On the other side i have also received the cast exhaust manifold from 53 willys and had began to work on my custom intake manifold. The good new is, that there will be no collision between the intake- (from VW LT 6 cylinder NA) and the exhaust manifold and the tubo. The bad new is, that the MK1 stock turbo (some kind of garrett) has lots of internal cracks in the housing.
I have compared them with my smaller BMW (524 TD, 2,5ltr.) stock turbo (K24) and have to say, that both are very similar from housing and compressor and turbine wheel diameter, although the bmw has 50% more swept volume. I will come back with some new pictures.
Best Regards
« Last Edit: May 24, 2009, 02:27:30 pm by Alleslowbuged »
BMW E28 524 TD
Reply #24May 26, 2009, 11:06:45 am
88jetta350
« Reply #24 on: May 26, 2009, 11:06:45 am »
Nice work, good to see another MKI GTD here in Germany.
Where in Germany are you?
« Last Edit: May 26, 2009, 11:08:54 am by 88jetta350 »
Reply #25May 26, 2009, 11:31:47 am
Alleslowbuged
  • 270
« Reply #25 on: May 26, 2009, 11:31:47 am »
Hi,
i am  in Bielefeld, if you look for other MK1 driver or information:
www.golf1.info
Best Regards
Clemens
BMW E28 524 TD
Reply #26May 31, 2009, 05:45:10 am
Alleslowbuged
  • 270
« Reply #26 on: May 31, 2009, 05:45:10 am »
Dear all,
here some new pics, from the installed seat and the fitted intake and exhaust manifold. The intake manifold is based on a 2.4 NA LT28 6 cylinder intake.
Best Regards
Alleslowbuged
BMW E28 524 TD
Reply #27June 23, 2009, 03:17:20 pm
Alleslowbuged
  • 270
« Reply #27 on: June 23, 2009, 03:17:20 pm »
Dear all,
i have remount the engine and after pulling the head, i has to realize, that there was water in cylinder 2, wich caused corrosion.
Anyhow, after two weeks with oil and diesel, i could remove the corrosion with very fine sandpaper and WD40.
I have also cleand the sealing face of the engine block.
Next step will be to fit the shifting device.
Best Regards
Clemens
BMW E28 524 TD
Reply #28June 23, 2009, 07:02:17 pm
Rabbit TD
  • 840
« Reply #28 on: June 23, 2009, 07:02:17 pm »
It looks to me like there are more of you here than anyother type, do you all know eachother  ;D
I remember back in the 60's when I was in the Navy an older lady saw me in my uniform one day and  said, "My Grandson is in the Navy too, do you know him? ??? ;D
Reply #29October 06, 2009, 02:28:22 pm
Alleslowbuged
  • 270
« Reply #29 on: October 06, 2009, 02:28:22 pm »
Hello,
not much process in the last weeks. In the moment i am workin on the gear shiftbox and the
conection to the gearbox. Also i have mount a hydraulic (fly off) rear brake, but i am not happy
with the position and i think i will change it again.
My cylinder head is a company for port ant polish, i shedule to get it back at the beginning of next
week. I will add some picture when it arrives here.
Best Regards
Alleslowbuged
BMW E28 524 TD
