Author Topic: hydraulic vs mechanical head - What's the difference?  (Read 14435 times)
February 04, 2008, 04:48:59 pm
hipifreq
  • 89
« on: February 04, 2008, 04:48:59 pm »
Forgive the newb question, but searching here and elsewhere didn't provide much info:
Can anyone help explain what the difference between a mechanical and hydraulic head are? What ways I can tell whether or not a head (or block) are designed to be hydraulic or mechanical? Post photos of the differences between the two? What are the implications for the two?
Reply #1February 04, 2008, 05:35:52 pm
KTZed
  • 170
« Reply #1 on: February 04, 2008, 05:35:52 pm »
I asked this same question when I first joined.
Generally speaking '86 and up came with hydraulic lifters. They require no adjustment, just use oil pressure.
Mechanical lifters require adjusting every *30,000 kms* (this number's just from memory and could be wrong...get the Bently check it for the service interval and adjustment procedure).
Theres a extra oil gallery on the front of the head (and consequently, the block) commonly referred to as the extra hump or bump seen circled in red.
Bump = Hydraulic
No Bump = Mechanical
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #2February 04, 2008, 05:55:39 pm
dieselsnowmobile
  • 103
« Reply #2 on: February 04, 2008, 05:55:39 pm »
Mechanical Heads are said to have a hair more power.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #3February 04, 2008, 09:43:33 pm
hipifreq
  • 89
« Reply #3 on: February 04, 2008, 09:43:33 pm »
KTZed: Thanks for the photo, that helps ID the difference. The cam and followers in your photo look similar, but does it have the shims that my mechanical head does?
Anyone have a good link to schematics with description of what's going on with the hydraulic? Without one in front of my I have a hard time "seeing" what's going on.
Yes, I've read a few different ideas about the hydraulic vs. mechanical debate. There's some that seem to think mechanical has extra power, but the need to check and adjust clearance seems to be a downer. Guess they never loved an air-cooled VW before. I'd check and adjust clearance every oil change with my old '71 bus.
The down side of hydraulic some people have stated is under high RPMs the oil gets compressed, which can affect the valve clearance as it doesn't lift as much.
Reply #4February 04, 2008, 10:15:25 pm
mufflerbearing
  • 61
« Reply #4 on: February 04, 2008, 10:15:25 pm »
hydraulic heads have 4 cam bearings where solid heads have 5.
im not too keen on how the hydraulic lifter actually works, but on a solid head the shim sits right on top of the lifter and is held in place by a small skirt around the edge of the lifter.
-j
Reply #5February 04, 2008, 10:21:25 pm
« Reply #5 on: February 04, 2008, 10:21:25 pm »
hydraulic lifters can become 'sticky'.. using a high quality oil can minimize this from occuring though.  i bet running a very good synthetic oil such as royal purple or lubro moly or one of those high end oils can minimize the need to adjust the valve clearance.  i found that my mech lifter engine was a work horse... it could haul some serious weight and not sweat like my current one with hydraulic lifters...  even if people say its a 'minor' boost in power, the butt dyno approves  8)
Reply #6February 05, 2008, 12:56:56 pm
hipifreq
  • 89
« Reply #6 on: February 05, 2008, 12:56:56 pm »
The picture of the hydro head agrees with libbybapa: One of the caps is off, but it definitely has 5 bearings.
So I've head about converting hydro to mechanical and vice versa. Is that an easy thing to do? I'm guessing it would involve plugging the oil gallery and replacing the followers with mechanical shim type, but no changes to the cam or other parts of the engine.
Does the hydro block have a different oil pump in order to get extra oil to head?
Reply #7February 05, 2008, 01:34:02 pm
« Reply #7 on: February 05, 2008, 01:34:02 pm »
yes the hydraulic engines should have a bigger oil pump as hydraulic heads 'leech' quite a bit of oil.
would be neat if there was a way to convert 1.9TD/TDI heads to mechanical  :wink:
Reply #8February 05, 2008, 02:19:44 pm
foxracer1
  • 991
« Reply #8 on: February 05, 2008, 02:19:44 pm »
The picture shown is a gasser head.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #9February 05, 2008, 02:56:12 pm
« Reply #9 on: February 05, 2008, 02:56:12 pm »
No, it's one of the newer integrated glowplug injector models  :lol:  :lol:
Reply #10February 05, 2008, 03:02:09 pm
subsonic
  • 1836
« Reply #10 on: February 05, 2008, 03:02:09 pm »
Quote from: "jimfoo"
Nice.
Reply #11February 05, 2008, 06:02:03 pm
KTZed
  • 170
« Reply #11 on: February 05, 2008, 06:02:03 pm »
Better?....Jeez
As far as im concerned hydraulic head is hydraulic head as long as it gets the job done....im not picky  :wink:
Reply #12February 05, 2008, 09:32:00 pm
Baselyne
mechanical
« Reply #12 on: February 05, 2008, 09:32:00 pm »
Quote from: "jtanguay"
I was wondering on pre 82 mechanical engines would it be possible to adapt the larger oil pump? its stright trade>?
are there two different vac pumps and oil pump shaft lengths?
Reply #13February 06, 2008, 06:05:19 am
« Reply #13 on: February 06, 2008, 06:05:19 am »
i've heard of some GM guy's modding the actual oil pump to increase the pressure... is this do-able with our vw oil pumps??? there must be a way!
Reply #14February 06, 2008, 01:58:21 pm
Baselyne
a hunch
« Reply #14 on: February 06, 2008, 01:58:21 pm »
perect thanks for the reply...
I wonder about the modding about the vac pumps too...
I assume the shaft on the gassers oil pumps are shorter as there would be a distributor there? Just a hunch.... anyone?
When and what size gears did they change to on the gassers?
Just so someone could get possibly the larger gears version off one of those non diesels
