Author Topic: Tiny-Tach  (Read 6220 times)
Reply #15February 15, 2008, 10:10:42 pm
  • 2932
Tiny-Tach
« Reply #15 on: February 15, 2008, 10:10:42 pm »
Can you take a picture of the transducer?
 I overtightened the one on my ferret timing light and ruined it.
 The tinytach ones are cheaper than a new ferret one but they won't send me a picture of it to see if I can use it for a replacement.
Reply #16February 16, 2008, 12:06:49 pm
hillfolk'r
  • 1532
Tiny-Tach
« Reply #16 on: February 16, 2008, 12:06:49 pm »
digital is a little hard to read(to me) in the heat of the moment
i got a lil 2 inch vdo diesel tach that runs off the w terminal
i  verified the accuracy with a diesel pulse adapter and a digital timing light/tach and adjusted it(the tach has an adjustment pot)
now i got a GTECH RR and it has a shift  light
now in the "heat of the moment" all i look for is the shiftlight on the gtech
tach is in the middle
shift light is 4 little leds on upper right side of gtech
Throttle cables ftw
Reply #17February 16, 2008, 11:28:52 pm
Tiny-Tach
« Reply #17 on: February 16, 2008, 11:28:52 pm »
Reply #18February 18, 2008, 01:54:54 am
  • 2932
Tiny-Tach
« Reply #18 on: February 18, 2008, 01:54:54 am »
Thanks for the pics.
 Pretty close to the one on my ferret 765.
 The ferret has a ground clamp that clamps to the injector line.
 Did the tinytach have a ground wire on the injector line?
Reply #19February 18, 2008, 05:00:12 am
saurkraut
  • 904
Tiny-Tach
« Reply #19 on: February 18, 2008, 05:00:12 am »
Quote from: "rabbitman"
They sell these sepparatly for $35.
Any one have ideas about running a gasser tac with this sensor?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #20February 18, 2008, 06:54:21 am
Tiny-Tach
« Reply #20 on: February 18, 2008, 06:54:21 am »
Quote from: "fatmobile"
Do you know what kind of signal it outputs off hand? I'm guessing a very low current but higher voltage?
Reply #21February 18, 2008, 06:56:21 am
Tiny-Tach
« Reply #21 on: February 18, 2008, 06:56:21 am »
Quote from: saurkraut
I would guess there wouldn't be enough pressure for it to detect as it's close to a factor of 100 less, but you can find out for only $35. :lol:
Reply #22February 18, 2008, 09:35:44 am
Tiny-Tach
« Reply #22 on: February 18, 2008, 09:35:44 am »
It's a piezio transducer so the output will be an extremely brief pulse of several hundred (if not thousand) volts... albeit at a very very low current.
It will also only give one pulse every two revolutions so will read  1/4 what a gasser tach will read.
I have one on the way and will do some digging with my oscilloscope when it gets here... first priority will be to design a timing light adapter for it... but a frequency quaduplier should not be too hard ;-)
EDIT: it's 1/4 of what a gasser tach will read
Reply #23February 18, 2008, 12:42:56 pm
Tiny-Tach
« Reply #23 on: February 18, 2008, 12:42:56 pm »
I don't think it would work on a gasser since it senses the injection by feeling the pulse through the Injector line.
There is a ground wire but it's under a valve cover nut.
Reply #24February 18, 2008, 01:42:35 pm
Tiny-Tach
« Reply #24 on: February 18, 2008, 01:42:35 pm »
yup... just did the math in my head... will edit the above posts for posterity !
