Author Topic: 2.4 pistons for 1.6  (Read 11134 times)
Reply #15February 02, 2008, 08:43:24 pm
935racer
2.4 pistons for 1.6
« Reply #15 on: February 02, 2008, 08:43:24 pm »
Quote from: "andy2"
2.4 engine /Pistons are oil cooled that I know for sure
Oh ok good to know, last time I saw one of those apart was like 4 years ago, hard to remember now.
I don't really like the idea of the 2mm less piston height though, I'd rather reduce compression with head modifications to the deck and pre cups.
Hey Andy how is your 1.9 coming along?
Reply #16February 03, 2008, 12:39:44 am
MJF
  • 581
2.4 pistons for 1.6
« Reply #16 on: February 03, 2008, 12:39:44 am »
Quote from: "935racer"
MJF do you have the weigt differences between the 1.9na pistons and the TD pistons?
Canīt remember exact, itīs been over a year since we weighed those. 1,6TD and 1,9na is ~same weigh, 1.9td is over 100grams heavier.
I have Carrillo rods, which I bought used from ebay. Those were locally fitted to my engine :D I havenīt lower compression, itīs actually a little higher than stock due bigger bore...
Iīve never disassembled a 1.9na, but it must have at least same length rod than 2.4. And that will be 150mm. Piston is same. 1.9td 144mm and 1.6 136mm
KY pistons are different than 1.9/2.4. Itīs same height than 1.6 piston IIRC.
E: This Mahle web-catalog is pretty handy 8)
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #17February 03, 2008, 09:07:30 am
935racer
2.4 pistons for 1.6
« Reply #17 on: February 03, 2008, 09:07:30 am »
So someone had the Carrillo rods custom made for this application and than you picked them up or are they meant for something else?
Why not use KY pistons?
Reply #18February 03, 2008, 10:01:50 am
MJF
  • 581
2.4 pistons for 1.6
« Reply #18 on: February 03, 2008, 10:01:50 am »
Rods are from Nascar SBC with Honda journals. 1.9 pistons are easier to find .
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #19February 03, 2008, 10:21:34 am
andy2
2.4 pistons for 1.6
« Reply #19 on: February 03, 2008, 10:21:34 am »
My project is waiting on some h beam rods as I don't feel like trusting the PD100 rods.I figured while I had the head off I'd go a step further and put the rods in now.Once I get It back together I'll have to cross my fingers and hope the turbo's will work.I'm determined to make the turbo setup work properly at all costs!
BTW great numbers Dave also are you using stock rods?Love to see the RPM on later dyno runs.The torque is Fairly conservative with the 1.6 so this might be what helps it hold together better than the 1.9.
Mabye I'll run honda rods too this time Nick :lol: .I was planning on getting the H beam TDI conrods that Kerma TDI sells.The TDI rod is the same dimentions as the 1.9td.
Reply #20February 03, 2008, 10:33:29 am
935racer
2.4 pistons for 1.6
« Reply #20 on: February 03, 2008, 10:33:29 am »
Thanks andy, I don't what the heck I did to get the time to come up instead of rpm, rpm was on the computer when we printed it out. Oh well the runs are saved on the computer at the new shop so I'll just get a screen shot on monday or tuesday. But iirc my peak is like 4900rpm and the boost drop was around 5400 or so, the run ended right at 6000rpm.
I am on stock rods, bearings and bolts! I put in ARP mains though, I didn't really do anything to the bottom end. No time, once the new shop is setup I will build a 1.7 bottom end and go for 250whp. The 1.7 should give me a little more torque, so would a smaller turbine housing. At no point does my emp pass my imp.
Reply #21February 18, 2008, 05:54:45 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
2.4 pistons for 1.6
« Reply #21 on: February 18, 2008, 05:54:45 pm »
A user by the name scopefrfd was doing something with 1.7 79.5mm pistons in a 1.6 block.
83 Rabbit LS Turbo Diesel
Reply #22February 21, 2008, 10:54:19 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
2.4 pistons for 1.6
« Reply #22 on: February 21, 2008, 10:54:19 am »
The 1.9 NA has oil squirters aswell. Atleast my AEF engine mounted in the 1999 Caddy (euroversion).
As far as I know all the 1.9īs has oil cooled pistons. All the NA engines Iīve disassembled had squirters. Might be some early models that didnīt.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #23March 06, 2008, 06:16:46 am
DA-BRT
  • 140
    • http://Zwalve.eu/
2.4 pistons for 1.6
« Reply #23 on: March 06, 2008, 06:16:46 am »
A friend of mine is building a 2100 TD based on a AAZ.
Walking through the Mahle catalog I found these pistons and after buying the pistons they were in my garage for a year. Than I desided to sell them and my friend bought them.
I'm using the 83.0mm pistons from a Ford 1.8TD. Same compression height. Pistonpin diameter. Only needed to cut out space for the oil squirter and a little extra clearance for the crank.
I already asked him for the buildup pictures. This monday or tuesday he is coming to have the pump and Injectors installed. (using a modified LT 2.8TDI pump) I'm going to take some pictures from it.
Reply #24March 06, 2008, 11:53:58 pm
DA-BRT
  • 140
    • http://Zwalve.eu/
2.4 pistons for 1.6
« Reply #24 on: March 06, 2008, 11:53:58 pm »
A couple of pictures of the 2100TD
Reply #25April 01, 2008, 02:38:18 pm
Torchd
  • 372
2.4 pistons for 1.6
« Reply #25 on: April 01, 2008, 02:38:18 pm »
Bert..
Which block are you using??  it seems to be 1.9 cuz of water jackets between the cylinders..
can i bore my 1.6block to use 1.7(KY) pistons?
Reply #26April 01, 2008, 11:28:24 pm
DA-BRT
  • 140
    • http://Zwalve.eu/
2.4 pistons for 1.6
« Reply #26 on: April 01, 2008, 11:28:24 pm »
The block that is used for this conversion is the 1900TD AAZ 1996 with crankshaft from a AFN.
Yes you can use them, but as allready discussed in this forum. Not all 1.7 Pistons are designed for oil squirters and they may not have the same strength as the 1.6TD version.
Reply #27April 01, 2008, 11:45:22 pm
Torchd
  • 372
2.4 pistons for 1.6
« Reply #27 on: April 01, 2008, 11:45:22 pm »
The ones i have do have the cut for oil squirters!!
Reply #28July 15, 2008, 04:09:18 pm
C.Sørensen
  • 3
    • http://www.sitecenter.dk/gimming
2.1l
« Reply #28 on: July 15, 2008, 04:09:18 pm »
Hello.
what headgasket do you use on this 2.1L ?
is it tdi rodīs your use ?
best regards Casper From Denmark
G       T        D
   Get  Things  Done
Reply #29July 16, 2008, 09:13:33 am
2.4 pistons for 1.6
« Reply #29 on: July 16, 2008, 09:13:33 am »
OMG!  :shock:
Now if only I could find 83mm TDI pistons.   :twisted:
