Author Topic: Pimping the glow plugs  (Read 35366 times)
Reply #30October 03, 2008, 11:54:21 am
« Reply #30 on: October 03, 2008, 11:54:21 am »
Yeah I used a starter solenoid w/ 2 small terminals, I tried using the solenoid housing as the ground but it was made to use the 2 terminals. I just remembered a while ago I had the engine/body ground come loose and that made the GP light flicker, the difference is the GP relay wasn't clicking so I don't thinks the GPs were actually lighting.
I'll check the new solenoid ground and make sure it's tight. I'll post some pics of the settup sometime.
Reply #31October 05, 2008, 02:47:55 am
FoXBoXRaCiNG
  • 92
« Reply #31 on: October 05, 2008, 02:47:55 am »
I've sourced a fuel pump relay out of a golf... Any good?
My cat has A.D.D :(
Reply #32October 06, 2008, 07:23:59 am
FoXBoXRaCiNG
  • 92
« Reply #32 on: October 06, 2008, 07:23:59 am »
Never mind, solenoid is the way!
My cat has A.D.D :(
