Author Topic: What a miserable end  (Read 8480 times)
March 31, 2005, 03:39:26 am
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« on: March 31, 2005, 03:39:26 am »
I got most of the accessories off my 1.6TD that threw a rod....here's the pics of the carnage.
and a closeup of the internals at this point.
I think a rod endcap bolt failed (do not re-use these) but the final diagnosis will happen when I get the oil pan off, etc.
Mikey
Reply #1March 31, 2005, 05:33:39 am
moTthediesel
  • 194
« Reply #1 on: March 31, 2005, 05:33:39 am »
It that what they call "Positive Crankcase Ventilation"?
Sorry, that's a big bummer  :cry:
Thanks for the reminder though, I'll be sure to use new bolts when I freshen up my TD.
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #2March 31, 2005, 09:37:59 am
dieselweasel
  • 312
« Reply #2 on: March 31, 2005, 09:37:59 am »
Did the rod bearing spin/seize or did the rod just break?
Reply #3March 31, 2005, 03:10:51 pm
Mikeyworks
  • 260
« Reply #3 on: March 31, 2005, 03:10:51 pm »
Not exactly...I think I may find tonight when I go to pull the rest of the bottom end off!!!!
Mikey
Reply #4March 31, 2005, 03:45:01 pm
Mark(The Miser)UK
  • 1557
« Reply #4 on: March 31, 2005, 03:45:01 pm »
:evil: If the hole is the only damage to the block; why cant the casing be patched and welded? :shock:
Mark-The-Miser-UK
Reply #5March 31, 2005, 03:48:58 pm
Mikeyworks
  • 260
« Reply #5 on: March 31, 2005, 03:48:58 pm »
Can you weld cast iron??
What about the water jacket?
Mikey
Reply #6March 31, 2005, 04:46:48 pm
Mark(The Miser)UK
  • 1557
« Reply #6 on: March 31, 2005, 04:46:48 pm »
Quote from: "Mikeyworks"
Mikey
Everything can be welded given the right bloke with the right torch :lol:
(Not me though I weld like I swim) :wink:
Does the water jacket reach down that far? :?:
Mark-The-Miser-UK
Reply #7March 31, 2005, 04:55:27 pm
Mikeyworks
  • 260
« Reply #7 on: March 31, 2005, 04:55:27 pm »
Quote from: "Mark(The Miser)UK"
Just checked...no waterjacket that far down...I will check with some of my friendly local skilled welders and see what they say about welding the block back together.  I would do that if I could before I try to sell it (if I do sell it).
Mikey
Reply #8March 31, 2005, 05:19:30 pm
Mark(The Miser)UK
  • 1557
« Reply #8 on: March 31, 2005, 05:19:30 pm »
Mikey
I know in the past people have looked at these incidents and after spewing up have just consigned the block to life as a boat anchor... Not me; something has to be truely trashed before I throw it out (and then it often takes the wife to bin it whilst I'm out) :roll:
 :twisted: Why it occurs to me that it might be patchable; is because there's only sump pressure there and as far as stress goes it looks like its right in the middle of 'nowhere' :twisted:
"Fingers crossed fer ya"
Mark-The-Miser-UK
Reply #9April 01, 2005, 02:10:25 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: April 01, 2005, 02:10:25 am »
:twisted: Maybe brazing is the way to go... :twisted:
Mark-The-Miser-UK
Reply #10April 01, 2005, 03:22:25 am
Patrick
  • 1034
« Reply #10 on: April 01, 2005, 03:22:25 am »
Brazing doesn't work very well. I've got a one lung gas engine here that was "ventilated" in a similar fashion. Pieces were put back in and brazed. Stayed together, but leaks. You might try a good tig welder with silicon/bronze rod though. Don't have much faith in cast rod.
Reply #11April 01, 2005, 05:01:04 am
« Reply #11 on: April 01, 2005, 05:01:04 am »
Mikey
Dibs!  ;)
84 Scirocco 8v
00 Camaro L36 M49
Reply #12April 01, 2005, 05:09:24 am
« Reply #12 on: April 01, 2005, 05:09:24 am »
OOh, had a brainstorm.  (watch out everyone)
A while back, there was a discussion about the maximum overbore of a 1.6 block - perhaps enough to fit 1.9 pistons.  If this block cannot be repaired, perhaps it would be a good donor to test by means of cutting it in half... etc. or just by boring it as far as it will go to see just how far it can actually go.
Hey, that way if the block is trash, then we can at least use it for research.   :twisted:
Just a thought.
84 Scirocco 8v
00 Camaro L36 M49
Reply #13April 01, 2005, 08:42:51 am
GoFaster
  • 22
« Reply #13 on: April 01, 2005, 08:42:51 am »
What's the bore diameter on a 1.6? I think it's only a couple millimeters less than the 79.5mm bore on a 1.9 engine. The stroke was a bigger difference.
'96 Passat TDI (looks stock)
Reply #14April 01, 2005, 04:30:26 pm
« Reply #14 on: April 01, 2005, 04:30:26 pm »
I think it's somewhere around 76.5 stock.  The highest (factory) overbore size is 77.5.  3mm sounds like a lot to me, it would be interesting to see how thin it would get.  (and if it could hold the pressure!)
84 Scirocco 8v
00 Camaro L36 M49
