Author Topic: 32.2MPG normal for a N/A diesel?  (Read 8788 times)
Reply #15January 31, 2008, 01:55:24 pm
« Reply #15 on: January 31, 2008, 01:55:24 pm »
It could have an ACH as well  I think
Reply #16January 31, 2008, 02:13:31 pm
89VWdieselGolf
« Reply #16 on: January 31, 2008, 02:13:31 pm »
that says 85 therefore it would be the CE1 reverse light connector correct??
although if it were, it would be 3495RPM
Reply #17January 31, 2008, 02:17:43 pm
« Reply #17 on: January 31, 2008, 02:17:43 pm »
that chart is not perfect although it is very good.
I don't own a lot of NAs, so who knows :lol:
Reply #18January 31, 2008, 03:43:21 pm
Luv My Volkswagen
  • 25
« Reply #18 on: January 31, 2008, 03:43:21 pm »
My diesel is 30 years old now and its gets 41 MPG. That's at a constant 75 MPH, driving 360 miles, one way. I can drive the full 360 miles and a big chunk of the way back before I have to fill up.
Reply #19January 31, 2008, 06:18:28 pm
89VWdieselGolf
« Reply #19 on: January 31, 2008, 06:18:28 pm »
ya but thats a consistent 360miles, so like that would be alot easier. Although 75mph is about 130kmh. we'll try the fuel filter, turn down the IP and see what happens[/quote]
Reply #20January 31, 2008, 08:54:27 pm
madmedix
  • 204
« Reply #20 on: January 31, 2008, 08:54:27 pm »
I commuted in a 92 NA for years and the moment I went above 120km/h, my milage went right into the outhouse. My mech at the time swapped out the 5th and waggled his finger at me repeating "below 120 to save the money!". I did it for two weeks: My wallet was thicker!  :D
120 seems to be the magic number no matter what with these cars. My experience anyway.
Cheers,
Andy
'90 TD Jetta
Reply #21January 31, 2008, 09:00:29 pm
« Reply #21 on: January 31, 2008, 09:00:29 pm »
the closer you can keep it to 2k rpm's, the better your mileage, but more strain on drivetrain components (if you're using a real tall 5th gear)
Reply #22February 01, 2008, 08:47:29 am
89VWdieselGolf
« Reply #22 on: February 01, 2008, 08:47:29 am »
i just read that page, but from what i gathered (which wasnt much to be honest :oops: ) is that mod is for a turbo car. If im reading it wrong and it can be used for an N/A car... what needs to be done?
edit... ok after reading it over again (and again) i see what they are trying to. So i need to adjust the screw that changes the fuel flow (the one VW puts a band around) until it reaches the right IP pressure
Reply #23February 01, 2008, 01:14:06 pm
89VWdieselGolf
« Reply #23 on: February 01, 2008, 01:14:06 pm »
ohhh ok i get it now.... just need to make up some gauge to measure it.... so does this work with both turbo and n/a's? and is the internal pressure supposed to be the same between the two. (again, i assume that thread if for turbo diesels)
Reply #24February 08, 2008, 09:06:51 pm
Diesel Fumes
« Reply #24 on: February 08, 2008, 09:06:51 pm »
Quote from: "89VWdieselGolf"
"AWY ('90 Diesel)" I assume thats mine (btw, i use that site all the time, its great!)
4147RPM :roll:
no wonder.
if i had an AUG (as crappy as they are) it would be 3863RPM, but that would be even worse acceleration.
BTW, i just ordered a new fuel filter
I had an AWY in my 90 Golf NA and I consistently got 55-60mpg.  It was a real screamer on the highway, but it was still efficient.
Reply #25February 26, 2008, 08:16:53 pm
blkboostedtruck
  • 1535
« Reply #25 on: February 26, 2008, 08:16:53 pm »
Quote from: "libbybapa"
There are a tremendous number of factors that can assist in producing poor fuel economy.  Here is a non-exhaustive list:  bad fuel, worn or improperly calibrated pump, improper pump or cam timing, old or improperly calibrated injectors, incorrect valve adjustment, improperly functioning hydraulic lifters, dirty air cleaner or other intake restriction, boost leak or pre-turbine exhaust leak on a TD, exhaust restriction,  restriction in the fuel line,  imbalanced or poor cylinder compression, worn accessory bearing such as alternator or a/c compressor, malfunctioning electrical system causing excessive drag on alternator, slipping clutch, improper transmission fluid or fluid level, worn or improperly lubed cv joints, worn or mis-adjusted wheel bearings, dragging brakes (which in turn can be caused by a variety of factors including but not limited to improper pedal freeplay adjustment, worn or corroded calipers, worn, dirty or corroded brake shoes, blockage in brake line, malfunctioning master or slave cylinder, malfunctioning brake booster), improperly balanced or improper tires, poor driving habits.
Andrew
you just described my N/A rabbit! minus the turbo! L.O.L.
i had a buddy make up a gage for the OUT bolt for a I.P. i can't wait to try it?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #26February 26, 2008, 08:18:53 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #26 on: February 26, 2008, 08:18:53 pm »
You forgot poor alignment :p
Reply #27February 27, 2008, 11:48:42 am
« Reply #27 on: February 27, 2008, 11:48:42 am »
increasing vehicle weight, roof racks, dino oil (debatable I'm sure), tire width, tire traction,worn steering components (resulting in bad/varying alignment), AC, PS, stereo setup, bad battery, driving with lights on (DRL can easily be disabled on mk2s), under inflated tires, warped rims, excessive idling,
Reply #28February 27, 2008, 05:35:46 pm
blkboostedtruck
  • 1535
« Reply #28 on: February 27, 2008, 05:35:46 pm »
I have no back seat in the rabbit and i use it like a truck and i haul around about 700lbs. tools for my ironworker carrier! i'm like a boy scout gotta be prepaired! the last time i figured my milage when i went down to the state of Georgia to get my caddy with a tow dolly i averaged 25miles to a gallon!
I guess at that milage? naa!! i'll still drive the rabbit!!
Duane
'66 variant 1500S
