Author Topic: Twin K03's on a 1.9?  (Read 6092 times)
Reply #15January 28, 2008, 08:46:44 am
MJF
  • 581
« Reply #15 on: January 28, 2008, 08:46:44 am »
Quote from: "burn_your_money"
Until the vanes seize up
Never had this problem  :shock:
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #16January 28, 2008, 09:38:31 am
935racer
« Reply #16 on: January 28, 2008, 09:38:31 am »
Bla, I hate vnt turbos, they don't flow worth ***.
Don't get me wrong some of the really knew VNT designs that are starting to pop out in the last 2 year are pretty decent and you can actually flow some air through the turbine, I think the newer audi diesel 3.0 liter engine has one of these turbos as well as the porsche 997, but the crap found on vw tdi's are just that.
Reply #17January 28, 2008, 09:44:34 am
935racer
« Reply #17 on: January 28, 2008, 09:44:34 am »
As for parallel twins on an inline engine, I would agree that with a split turbine housing you would be better off running a single, but if you were stuck with a single tang housing, than its going to be close to 6 of 1 and a half dozen of the other. Obviously twins requires a lot more fab and that should be factored into the undertaking.
Reply #18January 28, 2008, 01:19:03 pm
flash319
  • 163
« Reply #18 on: January 28, 2008, 01:19:03 pm »
I just put this out there to see what people thought.  I have the same idea that flow is flow.  1 big turbo or 2 small ones does not make much difference.  I guess we are all in agreement.  I was hoping someone would give a reason for doing it that I did not think of.  Guess I was right in thinking this way.
Reply #19January 28, 2008, 02:07:43 pm
« Reply #19 on: January 28, 2008, 02:07:43 pm »
Quote from: "OM617"
Personally, I'd rather get a few of those IHI micro turbos and have a turbo for each cylinder.
that would be pretty interesting... talk about complicated, but the possibilities...
Reply #20January 28, 2008, 04:37:38 pm
foxracer1
  • 991
« Reply #20 on: January 28, 2008, 04:37:38 pm »
Twins apparently work on an inline or there wouldn't be factory engines with them.(ACERT CATs) Thats not saying they are worth it on a small 4cyl VW. VNTs are great they are just in the early delvelopment.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #21January 28, 2008, 07:49:44 pm
OM617
« Reply #21 on: January 28, 2008, 07:49:44 pm »
Quote from: "foxracer1"
Those are not twins, they are compound turbos. Compound and series are very different from parallel twins.
Reply #22January 29, 2008, 04:38:21 am
foxracer1
  • 991
« Reply #22 on: January 29, 2008, 04:38:21 am »
Yes your right. oops
91 S10 305 TPI T56
Reply #23January 30, 2008, 08:21:30 pm
Tintin
  • 1279
« Reply #23 on: January 30, 2008, 08:21:30 pm »
No: 1, 4 cyl for 1 turbo, and cyl 2-3 for the second?  a lot of fun to find a place for this set-up, but I found that It's a nice and original set-up.
