Author Topic: Starting problems  (Read 6437 times)
Reply #15January 23, 2008, 11:02:39 am
Jetta Fan
  • 286
Starting problems
« Reply #15 on: January 23, 2008, 11:02:39 am »
Good to hear you found the problem. Reminds me, I need a battery for the Jimmy.
While you have the starter out, you should have it load tested anyway, just to make sure it is 100%. If your luck is anything mine, you'll put it back together and it will pack in next week and you'll have to do it all over again.   :roll:
1997 Jetta 1.9TD AAZ
Reply #16January 23, 2008, 06:17:15 pm
Starting problems
« Reply #16 on: January 23, 2008, 06:17:15 pm »
Quote from: "Baselyne"
batteries really dont keep well in the cold i guess
especially when they are left on a concrete floor  :shock:
Reply #17January 24, 2008, 09:33:25 am
Baselyne
Starting problems
« Reply #17 on: January 24, 2008, 09:33:25 am »
Yeah i know about the floor.. does it in!
Now Im going over the rest of the wires, Seems there are a few things not working. Fuel cut off, wipers, starter, glow plugs were on a switch to a old school looking relay..now 4 prong.. wires were falling off in my hand!
winters a goodtime to just freeze an fix most of the connections!
So is the fuel cut  off solnoid only suppose to have power when the switch is in on pos? I do beleave I just fixed it right before I came in but I gotta get somemore diesel to test her out! Power at the red/blk when key is on and none when its off...correct?
Reply #18January 24, 2008, 12:51:27 pm
Starting problems
« Reply #18 on: January 24, 2008, 12:51:27 pm »
Correct red/black is switched power. Make sure the stop solenoid also has power when the car is cranking
Reply #19January 28, 2008, 07:34:43 am
Baselyne
Starting problems
« Reply #19 on: January 28, 2008, 07:34:43 am »
thanks everyone for your in-put
I coulnd have figured it out without you... Now I know and will be able to help others...
thanks alot again everyone...Now i need to figure out this Glow relay BS
In the meantime i rigged them on a 4 prong but its not what VW intended I just dont really understand this diagram because the seatbelt relay and such are tired into it!
I understand wiring with few wires but once it gets all crissy crossy im f'd
