Author Topic: mk1 & mk2 down pipes?  (Read 2342 times)
January 10, 2008, 04:05:25 pm
cal
  • 49
« on: January 10, 2008, 04:05:25 pm »
are they the same shape? or will i find clerance issues with my mk1?
Reply #1January 10, 2008, 07:22:26 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #1 on: January 10, 2008, 07:22:26 pm »
Well it depends on what you are referring to as the downpipe. If you are referring to the cast iron unit that bolts directly onto the turbo, I believe they are the same or very close. The part that clips onto the cast iron part is totally different between the MKI and MKII and will not work.
Reply #2January 10, 2008, 07:52:34 pm
« Reply #2 on: January 10, 2008, 07:52:34 pm »
the cast iron piece is different and so is the lower down pipe, but u can make the cast iron piece from a mk2 work on a mk1 just gotta trim alot in order to clear the shift linkage
Reply #3January 10, 2008, 10:28:47 pm
« Reply #3 on: January 10, 2008, 10:28:47 pm »
Are you sure there is a difference between the upper downpipes? I know the lower ones are completely different. MK2 TD, MK1 NA and MK1 TD are all different when referring to the lower downpipe.
Reply #4January 10, 2008, 11:45:46 pm
cal
  • 49
« Reply #4 on: January 10, 2008, 11:45:46 pm »
i mean the downpipe that bolts onto the turbo that joins the rest of the exhaust system, i'm making a 2.5" system, just wondering if i can copy the shape of the mk2 system
Reply #5January 11, 2008, 09:57:40 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: January 11, 2008, 09:57:40 am »
Part no for the MKII unit is 191 253 805
Part no for the MKI unit is 171 253 805
I dont have the MKII unit sitting on the shelf so I cannot compare them but IIRC they are very similar. HTH!
