Author Topic: TD versus NA question  (Read 4218 times)
Reply #15January 13, 2008, 09:26:01 am
lyeinyoureye
  • 96
« Reply #15 on: January 13, 2008, 09:26:01 am »
Quote from: "Turbinepowered"
Because of the thermostat and it's functions, time to warm up the block/ initial warmup times shouldn't matter. The extra thermal mass in the radiator doesn't enter into the equation...
That is likely correct sir.  :)
Reply #16January 14, 2008, 04:59:18 am
lyeinyoureye
  • 96
« Reply #16 on: January 14, 2008, 04:59:18 am »
Were the thermostats and temp gauges the same?
Reply #17January 14, 2008, 07:35:32 am
DonGTI
  • 172
« Reply #17 on: January 14, 2008, 07:35:32 am »
In my case yes since on both rebuilds I used the same part number thermostat and as regards gauges I had the Mk2 16V GTI Motometer clocks in both my Golfs so gauges were the same, sender units were the same, and both gauge sets came off ebay  :P
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
