Author Topic: OM617.95 injector upgrade  (Read 5558 times)
January 08, 2008, 08:48:32 pm
OM617
« on: January 08, 2008, 08:48:32 pm »
The injectors are from the Canadian-only Volkswagen 1.9L AAZ with #265 nozzles from a 1987 300SDL and set to 150bar.
The results are good. Idle is significantly smoother and more quiet, idle exhaust temperature is 50*f cooler, top end feels somewhat stronger and there is less smoke when I nail the accelerator. No 0-60 time yet, I couldn't find a safe place to do it.
Only down side at this point is its harder to warm start without the glowplugs. Hopefully this will be resolved when I advance the pump after this tank of fuel is used up (I want to see if the injectors alone will cause any MPG change). I also threw in a super dose of Diesel Kleen to clean any carbon off of the used nozzles.
Here is a before and after video.
http://www.youtube.com/watch?v=6hmGSMiDo98
Reply #1January 08, 2008, 09:35:15 pm
« Reply #1 on: January 08, 2008, 09:35:15 pm »
One last look at my beautiful injectors. Be good to his engine.  :D
Good to hear they are working out well for you.
Reply #2January 08, 2008, 09:42:37 pm
OM617
« Reply #2 on: January 08, 2008, 09:42:37 pm »
It was a good thing I got yours. One nozzle from houseofdiesel was odd man out with a weird short spring, different spring base and doubled up shims.
I have two extra injectors to help people that can only find a set of four.
