Author Topic: oil pump  (Read 2576 times)
January 07, 2008, 11:52:08 am
moTthediesel
  • 194
oil pump
« on: January 07, 2008, 11:52:08 am »
I'm rebuilding an '85 Quantum engine now for my 356TD project. and I want to put in a new oil pump while I'm at it.
This engine is a solid lifter type, would it be worth while to install a newer style  oil pump from a hyd. lifter engine -- as I've heard that they are larger capacity? It also seems that the newer Meyle pump is actually about $20 cheaper  :?:
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1January 07, 2008, 12:34:48 pm
Baselyne
oil pump
« Reply #1 on: January 07, 2008, 12:34:48 pm »
im currious about this question also....
Are the pumps the same or?
Reply #2January 07, 2008, 02:48:33 pm
oil pump
« Reply #2 on: January 07, 2008, 02:48:33 pm »
Quote from: "libbybapa"
Later pumps are 36mm and will bolt right up.  I think it's a good idea especially on TD motors.
Andrew
Hell ya!!
Get the newer 36mm pump for sure.
Reply #3January 07, 2008, 03:00:24 pm
oil pump
« Reply #3 on: January 07, 2008, 03:00:24 pm »
Andrew
You just need new bolts because the 36mm pump is taller
Reply #4January 07, 2008, 03:02:07 pm
Gearhead
  • 87
oil pump
« Reply #4 on: January 07, 2008, 03:02:07 pm »
What engines had the 36mm pump?  I'm ordering online, and I know they were an OEM application.  Just want to make sure I'm getting the right one.
Thanks.
'82 2 Door 1.6N/A :( Rabbit  '85 Cabrio project
Reply #5January 07, 2008, 03:03:43 pm
rallydiesel
  • 1880
oil pump
« Reply #5 on: January 07, 2008, 03:03:43 pm »
Why not just get it from myke_w? He sells the right ones at a good price.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6January 07, 2008, 03:14:39 pm
oil pump
« Reply #6 on: January 07, 2008, 03:14:39 pm »
92 TDs defiantly had them but I'm not sure of the exact range
I agree, check with myke_w
Reply #7January 07, 2008, 03:40:46 pm
Gearhead
  • 87
oil pump
« Reply #7 on: January 07, 2008, 03:40:46 pm »
I would, for sure, but I'm ordering a few hundred $$$ of engine parts for a rebuild from autohausaz, not just an oil pump.   I'm getting free shipping.  Their parts are German unless noted, and the prices are fantastic.  I'm sure mike_w is a great guy to do business with, though.  Does he sell everything to rebuild an engine? How would I get in contact with him?  I wouldn't mind giving him a shot.
Reply #8January 09, 2008, 08:01:14 pm
CoolAirVw
  • 175
oil pump
« Reply #8 on: January 09, 2008, 08:01:14 pm »
I bought all my parts to rebuild my TD from Myke W.
36mm pump, new KB pistons, Rod bearings, main bearings, int shaft bearings, head gasket & bolts, gasket/seal set, mounts, injector nozzles, and some antifreeze hoses.
He gave fast service and every part was excellent quality.  All was German OEM I think except for the Glyco main bearings which If I remember right were Made in USA.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
