Author Topic: boost controllers?  (Read 2172 times)
January 05, 2008, 03:49:50 pm
cal
  • 49
boost controllers?
« on: January 05, 2008, 03:49:50 pm »
do they work on 1.6 idi's???
thanks in advance guys :)
Reply #1January 05, 2008, 03:54:29 pm
boost controllers?
« Reply #1 on: January 05, 2008, 03:54:29 pm »
yep.  they'll work on any wastegated turbo setup.  they basically limit the amount of charge air going to the wastegate to 'fool' them into thinking you're at a lower pressure.  this makes the wastegate open at higher psi, and should be adjustable.
they tee into the hose or metal line going into the wastegate. (looks like a can)
Reply #2January 05, 2008, 04:01:52 pm
cal
  • 49
boost controllers?
« Reply #2 on: January 05, 2008, 04:01:52 pm »
worth getting one???
Reply #3January 05, 2008, 06:24:18 pm
subsonic
  • 1836
boost controllers?
« Reply #3 on: January 05, 2008, 06:24:18 pm »
Depends.  What do you want to do?  How much boost do you want and what is your turbo set-up?
