Author Topic: diesel battery?  (Read 13889 times)
January 05, 2008, 07:24:25 am
boostaholic
  • 11
diesel battery?
« on: January 05, 2008, 07:24:25 am »
i have to purchase a new battery and am curious.. do you diesel engines need a higher cranking amp then gassers? or will just a standard battery do..
thanks
1990 jetta coupe diesel
Reply #1January 05, 2008, 07:28:29 am
DonGTI
  • 172
diesel battery?
« Reply #1 on: January 05, 2008, 07:28:29 am »
depends on what diesel engine you are running... but as a rule of thumb diesels do require higher amp batteries than equivalent petrol engines due to higher compression and the fact that the heaters* (Glow Plugs) and starter motor demand juice at the same time ...
*We call them heaters over here... my apologies
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #2January 05, 2008, 07:35:47 am
Baselyne
battery info
« Reply #2 on: January 05, 2008, 07:35:47 am »
You want it for the Glow plugs and starting...
I just bought a 1000 Cold cranking amp battery which Im interested in selling and i have all the orig reciepts and there still is warrenty
if you in ontario you'd get lucky
Pm me
Reply #3January 05, 2008, 07:35:57 am
boostaholic
  • 11
diesel battery?
« Reply #3 on: January 05, 2008, 07:35:57 am »
1.6 n/a thanks
Reply #4January 05, 2008, 09:09:46 am
Han Solo
  • 28
diesel battery?
« Reply #4 on: January 05, 2008, 09:09:46 am »
what about those ultra light batteries? i know gassers run them fine, but do they make any that can work well for a diesel?
Reply #5January 05, 2008, 01:08:46 pm
Baselyne
bottom line....CCA
« Reply #5 on: January 05, 2008, 01:08:46 pm »
A high amp battery is all your looking for...
Should be labled CCA then a number around the 500 - 1200 range
 I wouldnt even *** on a battery less than 800 CCA
Reply #6January 05, 2008, 01:52:45 pm
diesel battery?
« Reply #6 on: January 05, 2008, 01:52:45 pm »
I've run 650CCA batteries during the winter in my diesel with no problems. If there is nothing wrong with your battery don't worry about it but if you are buying a new one get one with the highest CCAs that you can afford
Reply #7January 05, 2008, 02:10:14 pm
Baselyne
diesel battery?
« Reply #7 on: January 05, 2008, 02:10:14 pm »
thanks you, that's what i was trying to say....Burn's the man
Reply #8January 05, 2008, 03:28:29 pm
diesel battery?
« Reply #8 on: January 05, 2008, 03:28:29 pm »
Quote from: "burn_your_money"
even in north bay? must have been a pretty big 650CCA battery... i've lived in Timmins and it gets stupid cold there (only an hour away i think).  i doubt a 650CCA batt would start a diesel there at -40C.
i have a 700CCA battery in my car right now.. its alright but has a little bit of a rough time starting the car at -10 and beyond.  might also be normal tired engine syndrome though too...
Reply #9January 05, 2008, 03:31:05 pm
Baselyne
diesel battery?
« Reply #9 on: January 05, 2008, 03:31:05 pm »
do you mean the Glow plugs? Does burn use his block heater in -40?
Reply #10January 05, 2008, 03:44:12 pm
diesel battery?
« Reply #10 on: January 05, 2008, 03:44:12 pm »
I had a 10 year old VW dealer 650 CCA battery and the car was not plugged in at -40 and it started. I had to try 3 times before it started and stayed running. It had been sitting outside since it last ran for about 6 hours
Reply #11January 05, 2008, 03:50:22 pm
diesel battery?
« Reply #11 on: January 05, 2008, 03:50:22 pm »
the motor must have been in good shape then.  my old jetta wouldn't even turn over at -32C a few years ago... what a PITA.  (that battery was a 650CCA) of course it could have been bad connections to the starter i suppose...
Reply #12January 05, 2008, 04:08:47 pm
diesel battery?
« Reply #12 on: January 05, 2008, 04:08:47 pm »
Rotella T SB 0W40 and good battery/starter connections
The engine had 450k kms on it, it wasn't that good.
Reply #13January 05, 2008, 04:23:18 pm
flash319
  • 163
diesel battery?
« Reply #13 on: January 05, 2008, 04:23:18 pm »
I would not go on cold CCA only.  That is one of those numbers that can be fudges to suit what you want.  How much you can draw from a battery at one time is not a good rating for a battery IMHO.  You are limited by cable size anyway.
I have found that batteries are like many things, you get what you pay for.  Stay far away from Canadian tire garbage.  Get a good name brand (Interstate) and as big (physicaly) as you can get into the tray.  You need lots of juice (Ah) when you have to crank it over for a long time with the glow plugs when it is -40.
I didn't see where you live but I think if it is warm all the time then there are no special needs for the diesel.
Reply #14January 05, 2008, 04:28:56 pm
diesel battery?
« Reply #14 on: January 05, 2008, 04:28:56 pm »
Quote from: "wikipedia"
Cold cranking amps (CCA) is the amount of current a battery can provide at 0°F (−18°C). The rating is defined as the amperage a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). It is a more demanding test than those at higher temperatures.
I don't see how this can be fudged
