Author Topic: Changing Thermostat  (Read 4565 times)
January 04, 2008, 11:11:23 am
yeagerjf
  • 12
Changing Thermostat
« on: January 04, 2008, 11:11:23 am »
Does anyone know of a link to step by step instructions to install a thermostat on a 1.6L NA?
Reply #1January 04, 2008, 11:21:40 am
Zulfiqar
  • 254
Changing Thermostat
« Reply #1 on: January 04, 2008, 11:21:40 am »
dont know of any links - but here goes a step by step
tools,
allen wrenches, WD40 can, jackstands if you are on the heavier side
get under the car and remove lower coolant pipe from pump to drain rad,
once drained - get your handy WD40 and spray those little allen screws holding the elbow to the pump, then fit an allen key (5mm if I recall) and unscrew them, be very very gentle - its usually corroded and will break off from the pumpbody side if you manhandle it.
replace thermostat with new ring and button her up,
easy said than done, I can swear that the VW engineer had 8 joints per finger considering the pump location and the pipe connections
Diesel IS the future
Reply #2January 04, 2008, 11:31:46 am
Changing Thermostat
« Reply #2 on: January 04, 2008, 11:31:46 am »
If you have power steering you have to remove that first.
On all the cars I've ever worked on it was either 10mm or a 13mm bolts holding the elbow on, not allen.
You need to drain all the coolant. remember that when you remove the actual thermostat more coolant will be released from the engine
Reply #3January 04, 2008, 11:39:04 am
Changing Thermostat
« Reply #3 on: January 04, 2008, 11:39:04 am »
One other trick... it's a good idea to test your new t-stat in boiling water for proper operation *prior* to installation... many many many people have found out the hard way that new ones sometimes don't work.
Reply #4January 04, 2008, 06:33:47 pm
dieselsnowmobile
  • 103
Changing Thermostat
« Reply #4 on: January 04, 2008, 06:33:47 pm »
Also, put a shop vac to the upper rad hose that comes out the the head when putting the thermostat in.  This will put a vaccum inside the engine's cooling system and it helps hold the T-Stat in and it helps to hold the rubber gasket while you put the elbow in.  I read that someone else did it, so I tried it and it works great.  Just let the shop vac run and it will hold it in place.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #5January 04, 2008, 06:40:53 pm
Changing Thermostat
« Reply #5 on: January 04, 2008, 06:40:53 pm »
Quote from: "dieselsnowmobile"
This is a really really *cool* idea... you can spend quite a while under there wondering if it slipped when you put the flange back in.
Excellent tip !!
Reply #6January 04, 2008, 09:27:12 pm
Changing Thermostat
« Reply #6 on: January 04, 2008, 09:27:12 pm »
Yes thank you, that's genius
Reply #7January 04, 2008, 11:31:21 pm
Zulfiqar
  • 254
Changing Thermostat
« Reply #7 on: January 04, 2008, 11:31:21 pm »
Very strange to have allen screws on mine then. and the elbow is made of cast aluminum rather than the plastic everyone speaks here of.
Reply #8January 04, 2008, 11:36:44 pm
Changing Thermostat
« Reply #8 on: January 04, 2008, 11:36:44 pm »
Aluminum was used on the MK1s, all later cars had the plastic elbows IIRC
Reply #9January 05, 2008, 12:00:21 am
Changing Thermostat
« Reply #9 on: January 05, 2008, 12:00:21 am »
if they aren't corroded the Al ones are much better imho... the plastic type warp with heat over time and cause leaks.
I grab the Al ones from the junkyard and swap them in for the plastic version whenever I get a chance.
Reply #10January 06, 2008, 02:03:49 am
Zulfiqar
  • 254
Changing Thermostat
« Reply #10 on: January 06, 2008, 02:03:49 am »
maybe it has to do with the fact that all the flanges in my engine are aluminum.
btw is a geba pump worth running - ive scored a brand new one from a post office auction for 500 Rs (more like 9 USD)
Reply #11January 09, 2008, 02:10:45 pm
smutts
  • 720
    ClackClackClackClackClack
Changing Thermostat
« Reply #11 on: January 09, 2008, 02:10:45 pm »
Simply roll the car onto it's roof. This makes thermostat installation a doddle. Or superglue works well for the less gullible. :)
Reply #12January 09, 2008, 09:17:58 pm
DonGTI
  • 172
Changing Thermostat
« Reply #12 on: January 09, 2008, 09:17:58 pm »
Smutts... In absence of a shop vac I was going to hint a drop of superglue myself  :P  then again i even use it to hold a new clutch in place so its quite a reliable way to hold stuff in place during reassembly (if not too much is applied)...
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #13January 22, 2008, 09:26:17 pm
yeagerjf
  • 12
Changing Thermostat
« Reply #13 on: January 22, 2008, 09:26:17 pm »
Vacuum on the upper hose worked like a charm.  Thanks for the tip.
Reply #14January 23, 2008, 04:14:04 pm
dieselsnowmobile
  • 103
Changing Thermostat
« Reply #14 on: January 23, 2008, 04:14:04 pm »
Yep, No Problem.  If I remember who told me or where I read that, I would give them credit.
