Author Topic: Tranny Oil?  (Read 2859 times)
March 24, 2005, 06:10:43 pm
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
Tranny Oil?
« on: March 24, 2005, 06:10:43 pm »
My Bentley manual says to use hypoid oil for the manual transmission, but it doesn't specify a weight.  I already have some synthetic 80W-90 gear oil.  Can I use that?
Thanks
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #1March 24, 2005, 06:17:37 pm
dieselweasel
  • 312
Tranny Oil?
« Reply #1 on: March 24, 2005, 06:17:37 pm »
You can use your 80w-90, although synthetic is a better choice.  80w-90 or 75w-90 is good for viscosity.
Reply #2March 25, 2005, 04:28:47 am
Patrick
  • 1034
Tranny Oil?
« Reply #2 on: March 25, 2005, 04:28:47 am »
You might find the 80W90 a little thick when the car is cold. If it's really cold, you'll need the clutch shoved in to start the car, and the car will actually try to move when you let the pedal out! :lol: that's what's in mine now. Oil is thick enough to drive the car to an extent. Works fine though. I am going to go to something a little lighter before next winter.
Reply #3March 25, 2005, 06:00:45 am
Northboundtrain
  • 131
Tranny Oil?
« Reply #3 on: March 25, 2005, 06:00:45 am »
So would 80W-90 be too thick even if it's synthetic?
'91 Jetta 1.6L NA
Biodiesel
Reply #4March 25, 2005, 06:11:19 am
chrissev
  • 694
Tranny Oil?
« Reply #4 on: March 25, 2005, 06:11:19 am »
Quote from: "Northboundtrain"
if you want really good tranny fluid use Redline MTL.  It's expensive but more than worth it for the increased performance and it makes gear shifting in cold weather like shifting in warm butter.  No more grinding or baulky gears when it's cold outside.
Reply #5March 25, 2005, 06:14:25 am
racer_x
  • 123
Tranny Oil?
« Reply #5 on: March 25, 2005, 06:14:25 am »
If it's 80W90, it might be to thick. The viscosity doesn't change just because it's synthetic (unless the numbers are different).
One other thing, synthetics tend to "clean" things up pretty thoroughly, and that can open some leaks that might be plugged with dirt/gunk now. So it's a really good idea to check the level frequently after switching from conventional oil to synthetic, and watch out for leaks and drips.
Most of the bad transmission problems I've had in my past were in the weeks immediately following a switch from conventional lube to synthetic lube in the transmission, and the leaks and low lube running that followed that. Now, I only change after a clutch change when I also change out all the seals on the transmission. And I don't experience leaks any more.
One good diagnostic indicator for transmission lube level is the temperature indicator labels that permanently change when they go over a certain temerature. One of those that indicates 200-250F on the end cap of the transmission will quickly tell you if you have a problem with the lube being low. With a full transmission, it will never go over 250F there. But if it's running low, it will get very hot on the end, especially on longer highway trips, and the label will tell you.
