looking for a quick answer - stock 1.6td boost psi
Topic: looking for a quick answer - stock 1.6td boost psi (Read 4078 times)
December 29, 2007, 11:54:31 pm
okron1k
December 29, 2007, 11:54:31 pm »
how much boost does a stock 1.6td make? vw jetta 1992.
December 30, 2007, 12:01:09 am
compu_85
User+
December 30, 2007, 12:01:09 am »
9-10 PSI
99.5 Jetta GLS TDI. 219k miles
91 Jetta GL ECOdiesel. 400k miles+ Sold.
91 Mercedes 350SDL. 202k miles.
December 30, 2007, 12:07:24 am
okron1k
December 30, 2007, 12:07:24 am »
hmm.. i wonder if the guage is reading bad or i am just not getting that high.
when i bought the car it had a line already run and ready for a boost guage. my buddy won a boost guage off of dubmodder a while back and gave it to me for a case of beer. i just decided to put the line into the guage and it seems i can only hit 8psi.
any easy way to dial up the boost without going and buying a boost controller?
December 30, 2007, 12:16:07 am
December 30, 2007, 12:16:07 am »
does your car smoke a lot? you can increase the boost fueling by taking off the top of the LDA and the bin and turn the starwheel i think its clockwise? make note of the clicks so you can return it to normal if you like. i would try about 5 clicks.
December 30, 2007, 12:32:12 am
okron1k
December 30, 2007, 12:32:12 am »
it does smoke quite a bit. compared to an identical jetta. previous owner did something to it but i don't know what. but under heavy throttle i can put out a nice little cloud
i think that my starwheel is messed anyways. i have no idea where stock is because previous owner was in there most likely as well as myself. i returned it to what i found it at but i'm not sure about what previous owner did. maybe giles can do some magic when i get some spare money.
December 30, 2007, 03:47:52 am
bert
December 30, 2007, 03:47:52 am »
Remember the blow off valve will open if you try to raise the boost,it will need sealing shut :wink: i hit 22 psi with a garrett T2 in a 1991 sb jetta TD
Bert
December 30, 2007, 07:07:21 am
okron1k
December 30, 2007, 07:07:21 am »
what's a good way to go about sealing it?
December 30, 2007, 09:41:16 am
bert
December 30, 2007, 09:41:16 am »
I took the valve off,cleaned it and filled it with silicone and pushed a plastic bolt into it with a big head and let it set,put a bit more silicone on top then put it back onto the manifold,you will see when its removed :wink:
Bert
December 30, 2007, 10:52:01 am
December 30, 2007, 10:52:01 am »
Quote from: "okron1k"
Given the accuracy of the average automotive gauge and the average wastegate I think you're fine... the Bentley says 9psi is average for a 1.6l .
December 30, 2007, 12:24:40 pm
okron1k
December 30, 2007, 12:24:40 pm »
10-4 good buddy
it's a vdo guage.. i hope it would be somewhat accurate.
December 30, 2007, 04:34:38 pm
compu_85
User+
December 30, 2007, 04:34:38 pm »
Well what is your gauge showing?
-J
