Author Topic: Stainless fasteners  (Read 5842 times)
December 29, 2007, 05:38:56 am
stewardc
Stainless fasteners
« on: December 29, 2007, 05:38:56 am »
Whenever I work on the truck, I like to replace the bolts I use with stainless bolts. Does this create a corrosion problem (dissimilar metals) if I were to change oil pan bolts, for instance??
Reply #1December 29, 2007, 06:55:20 am
Stainless fasteners
« Reply #1 on: December 29, 2007, 06:55:20 am »
Only if you have an aluminum oil pan.
Reply #2December 29, 2007, 07:06:52 am
QuickTD
  • 1156
Stainless fasteners
« Reply #2 on: December 29, 2007, 07:06:52 am »
No real corrosion problems that I can forsee. You should be aware that stainless bolts are not as strong as alloy steel bolts, particularly in fatigue strength. This is more of a concern on heavily stressed areas, such as in the suspension or engine mounts. I wouldn't worry much about pan bolts.
Reply #3December 29, 2007, 07:25:57 am
stewardc
Stainless fasteners
« Reply #3 on: December 29, 2007, 07:25:57 am »
Thanks, guys. The only bolts that will go stainless are small, visible ones. Any loadbearing ones will probably go titanium :P
Reply #4December 29, 2007, 07:39:30 am
FineFrank
  • 72
ss bolts
« Reply #4 on: December 29, 2007, 07:39:30 am »
Remember to use the right antiseize on them, too. SS bolts REALLY need it because they break a bit easier than carbon steel.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #5December 29, 2007, 07:47:38 am
stewardc
Re: ss bolts
« Reply #5 on: December 29, 2007, 07:47:38 am »
Quote from: "FineFrank"
What is the best antiseize to use?
Reply #6December 30, 2007, 06:12:23 am
Pat Dolan
  • 163
Stainless fasteners
« Reply #6 on: December 30, 2007, 06:12:23 am »
Stainless bolts in steel or cast iron do not need anti-seize compound.  However, stainless in stainless (i.e. nut-and-bolt joint) ABSOLUTELY REQUIRES anti seize compound.  There are usually three different ones:  high temp, low temp and stainless compatible.  Any supplier that can make those differentiations is selling you a good, commercial grade product.
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
