Author Topic: Head gasket question  (Read 3008 times)
December 25, 2007, 11:24:40 am
dieseldunebuggy
  • 24
« on: December 25, 2007, 11:24:40 am »
I have the early 1981 1.6l diesel engine with the 11mm head bolts. If I drill out the holes for the 12mm head bolts, will the 12mm head gasket work? I was told the oil passages are different.
1981 Volkswagen Rabbit L custom 1.6l N/A
-Stainless Steel Header
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #1December 25, 2007, 11:38:10 am
vanagonturbo
  • 639
    • Fine Tuning
« Reply #1 on: December 25, 2007, 11:38:10 am »
Why are you trying to use the 12mm gasket?
Reply #2December 25, 2007, 12:09:25 pm
dieseldunebuggy
  • 24
« Reply #2 on: December 25, 2007, 12:09:25 pm »
Well if I put 12mm head bolts in wouldn't the holes be to small in the 11mm head gasket?
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #3December 25, 2007, 12:52:50 pm
ilomax
  • 86
« Reply #3 on: December 25, 2007, 12:52:50 pm »
Huh?
Did you switch the head or the block?
Why are trying to put in 12mm bolts?
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #4December 25, 2007, 01:09:55 pm
dieseldunebuggy
  • 24
« Reply #4 on: December 25, 2007, 01:09:55 pm »
Everything is the stock 11mm. I want to put in 12mm head bolts so I won't blow the head gasket as easy when I do some performance mods on the engine.
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #5December 25, 2007, 04:02:49 pm
Dsldub
  • 8
« Reply #5 on: December 25, 2007, 04:02:49 pm »
edited for content
Reply #6December 25, 2007, 09:16:00 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #6 on: December 25, 2007, 09:16:00 pm »
The jury is still out on the metal head gasket on my scirocco so I cant really recommend that at this time.
Be careful about the ARP if you dotn plan on retorquing them. They will need it over time.
Try to source an NA 12mm block if your funds are limited.
Reply #7December 25, 2007, 09:58:32 pm
ilomax
  • 86
« Reply #7 on: December 25, 2007, 09:58:32 pm »
Ahhh, I got ya now.
I would personally go with the head studs or source out a 12mm head and block (or at least a block and drill out the head)
Reply #8December 28, 2007, 05:18:34 pm
dieseldunebuggy
  • 24
« Reply #8 on: December 28, 2007, 05:18:34 pm »
I have ordered some 11mm ARP head studs from ARP. Thanks for all your help.
-Huge Custom Intake
-Ported Head
-Lightened Flywheel
-ARP Headstuds
-GILES PUMP
Reply #9December 29, 2007, 06:12:44 am
oldskool rich
  • 446
« Reply #9 on: December 29, 2007, 06:12:44 am »
aaz is 11mm isnt it?
where can you get these studs from? i asked the ARP dealer on ebay and he told me that they dont make them.
also how much are they?
f6squared I.D.S.T
Reply #10December 29, 2007, 06:48:49 am
« Reply #10 on: December 29, 2007, 06:48:49 am »
AAZ are 12 mm. Do a search for ARP on the forum and you will find the #s. In ARP's book, they are listed for a Cosworth.
